First Time PS owner
I am picking up a 04 f350 tonight. Looking for mods that help on MPG. Thinking a nice 4" exhaust system.
The right foot mod has helped my mileage the most.
True true. It is the cheapest mod but very difficult to install.
tuner helps out.. fuel additive helps a bit too - i've noticed a small boost with my stanadyne
Unfortunately your going to need to experiment as to what will give you an increase in mpg. People can come on here and say this helped them out or that helped them out. There is no promise that any of that stuff will help you out because there are too many factors that come together for mileage efficiency some you can control others you cannot.
More often then not people that say "this or that boosted my mpg" can't really say definitively that one mod truly did it boost it. Most people's best level of evidence(by most I mean atleast 51% as that would be technically most) is that "I did this mod or I started using this and then I noticed an improvement", while that mod may have contributed to that improvement, there might have been something else that did as well in conjunction with that mod. Might have did an oil change or even switched to synthetic oil(I have calculated better mpg readings when I have fresher oil in there). Wind may not have been bad or maybe driven in terrain that wasn't as harsh on efficiency(not as hilly etc). Most people don't take into account the other variables when they do their calculations, it's usually miles driven compared to gallons consumed, that really doesn't give you percentages of what went there. If you knew an exhaust system contributed say 7% towards efficiency, it would take awhile to pay for that exhaust, same with the tuner. I'm not saying the things listed above didn't help mpg, they very well might have, but how much did they help? That will help in determining if it will pay for itself for your use during the time that you will have your truck. Only way you'll know rough precentages on what contributes how much to mpg is if you do a whole host of other calculations considering other facts that I know I wouldn't do and I'm willing to bet damn near everyone else doesn't do them either. The moral of this long winded post is in doing mods you might want to put focus on something other then mpg efficiency as your primary focus, while you might see an improvement, how much really goes to that mod you did isn't easy to determine definitively. |
I did the MBRP from turbo backwith 3.5 down pipe to 4" exhaust lol I should have just got a straight pipe for the down pipe and used 3.5 pipe to replace my cat and muffler and saved $550 dollars . No reason for big pipe unless your doing high HP !
This is nice to know. High HP? Above like 400?I am thinnking just an econ program.
4" exhaust is recommended if your running a tuner and a 5" exhaust if you start messing with injectors and turbo upgrades. If you go to 5" with just a tuner, you'll actually lose some low end torque. You might be able to offset that lose with a good amount of overfueling, but I wouldn't go that route. |
Then again if your not going Hp like over 400 yeah 3.5 will be just fine but 4" will cool your egt's dow some. But just a 60 or 80 eco tune I would not worry at all. Beside I had my street tune in and was pushing it hard as hell and could not reach over 900 egt's ...
Your pyro isn't post turbo is it? I could easily get past 900 with my tow or street tune when all I had was a tuner, hell I remember hitting that when I was stock with the truck trying to get baseline temps and psi to compare when I started using my tuner. Either your pyro is in the wrong spot or your tunes might be a little on the weak side.
