EGT question??
Ok well i have a bullydog pmt that i am using as a gauge set up. And i have the egt probe but its installed post turbo at the bottom of my down pipe. I dont have enough funds right now to install another egt probe pre turbo. So what i was wondering is whats the temp diffrence between pre and post turbo??? I mean my egts are usually around the high 600s to the low 700s on normal driving. But is that the same temp at pre turbo???
There is usually quite a large difference between pre and post turbo with pre being a lot hotter....somewhere in the range of one to 400 degrees. The vast majority of folks run a pre turbo and some even run both, so maybe one of the more experienced will chime in.
a reputable diesel tech told me as a good rule of thumb, theres an average 150 degree temp difference pre and post turbo. but i agree with above, tap into your manifold for your egt. not much of an issue around town, but when you're standing in it pushing over 1k its a different story.
I'm not sure there is one here, but there are several forums with that info. Drivers side manifold is typically where it's installed, but passenger side will probably give you better information.
Gauge Installations at DieselManor- 2003-2007 6.0L Powerstroke
Go to the second page and click on the pic that shows the EGT probe in the manifold. As others have been saying if your EGT is post turbo like right at the turbo its prob a 150 difference, if you are talking 3 feet down the downpipe, Good Lord!!! its somewhere between 150-500 off who knows.
wow it being that low i can easily see 200+ diff... prob more depending on how far down you installed it
-Raul |
