6.0 Stage I cam.....imput
I was thinking od having a stage I cam installed in the engine AI am having built......what do you guys think about the cams? Who is running them and what are you seeing or what are you guys hearing from people who are running them.....I know springs will be a must with them.........
I have never seen much talk about cams on here, I'd be interested in seeing some info on this also. @dukcaln, what part of Cali you from bro?
I an near Napa..........You....As for the cam, i am hearing it will make a wider power range and increase the rpm into the 4k range.......along with some good porting on the heads and intake manifold and cleaning the exhaust manifolds up it should produce some power.....
Not worth it unless you're going for crazy high power.
It's your money, and if I was doing a performance build like your doing I would go for the cam. There is definitely some room for improvement over the stock unit. I've seen how you feel about Elite, but Tadd would be the one to get the skinny from on the benefits of the camshaft.
I spoke with elite today and it seems that there will be some benefits to adding a stage 1 cam.....I am going for it
you will have to do some really really really good porting in the heads to get the performance out of the cam. the cheaper solution to the cam is spray. the cam doesnt do as much as you think it will, ive seen the dyno results from a truck with a stage 1 cam and it wasnt anything that open'd my eyes any bigger
So I see your stickin with a 6.0
It will prolly add a really cool lope
