Injectors - Ford Powerstroke Diesel Forum
Old 04-21-2009, 07:19 AM
Injectors
I drive an 03 6.0 all stock exept for a leveling kit and tiers. i an putting a cut out system on it this weekend.
would bigger injectors hurt my engine more than they would help.
what are the pros and cons?
Old 04-21-2009, 07:22 AM
you would need some more supporting mods like fuel system or some kind, a programmer to keep up with the added fuel.
what do you want bigger injectors for? power? towing?
Old 04-21-2009, 07:25 AM
i want it for mostly power and i would like the truck to put out some smoke.
i did not realize it took so much to make these trucks smoke.
i dont really want to do a programer they are just so expensive.
Old 04-21-2009, 07:26 AM
whats a cut out system?
your gonna need other stuff before you do injectors ie: SCT, Gauges, Exhaust, Studs, might as well delete the EGR while your doing the studs.
You wouldn't get much benefit out of really big injectors unless you also upgrade your Turbo.
Old 04-21-2009, 07:27 AM
a set of injectors run about 3 grand
Old 04-21-2009, 07:28 AM
man o' man looks like i am leaving 'er stock
Old 04-21-2009, 07:29 AM
Send a message via AIM to jhaddox
you dont need injectors to make the truck smoke...just get an sct tuner with custom tuning and youll be good to go and thats only around 450 dollars...everyones truck on here will smoke with a tuner...a good amount too...your not gonna need injectors just to get a little black smoke out of the truck
i cut out system is a way to have your stock exhaust and a way to run straight pipe under the truck.
Old 04-21-2009, 07:30 AM
how much does that run me
Old 04-21-2009, 07:31 AM
o i see i miss read thank you
