switching automatic to manual - Ford Powerstroke Diesel Forum
Old 04-19-2009, 05:02 PM
Send a message via AIM to Stroker60
has anyone ever done this or know where i can find info on how to do this??...just wanna see what all i would get into to do this
Old 04-20-2009, 11:50 AM
ok, guess nobody cares or knows anything about it
Old 04-20-2009, 12:04 PM
BOSS LEVEL
its involved. i think most of the wiring is already in place, but you will need the pcm that controls the shifting, a different instrument cluster, shift linkage, different drive shaft, coolers, and a steering column cover. i think thats it.
ive heard of trucks going from auto to manual. but havent heard or dont remember reading from going from manual to auto.
Old 04-20-2009, 12:52 PM
You definitely DO NOT need all that stuff to swap a manual in your truck.
I'm getting ready to swap a manual in mine next month.
Here is the basics of what you need for a 7.3l. Not sure what what be different on the 6.0.
transmission
new PCM(from a manual tranny truck)
Transmission
new imput shaft for the transfer case(or a new transfer case), because the splines are different on the manual
clutch pedal assembly
master/Slave cylinder assembly including reservoir
new flywheel
clutch kit
Got change a few wiring things.
and a few other things
thats the basics
The steering column is the same, you just have to change over to some of the manual pieces.
I'm not gonna mess with it for the time being, nore the instrument cluster, but that is personal preference. Just gonna get the swap done, and the truck driveable worry about that stuff later on
Old 04-20-2009, 12:58 PM
BOSS LEVEL
Originally Posted by CoalRollinRoosterCruiser View Post
You definitely DO NOT need all that stuff.
transmission
Transmission
new flywheel
clutch kit
thats the basics
ok im a once again.
i miss read it apparently.
sorry.
coalrollin dude said what needs done.
