Exhaust - Ford Powerstroke Diesel Forum
Old 04-19-2009, 03:09 AM
Exhaust
Considering the MBRP turbo back for the 04 F250. While I'm sure the stainless steel is far superior, my cheap *** will probably end up with the aluminuzed steel. Anyone running this system? Just wondering how many Pennsylvania winters it's gonna survive before it's a rusted hunk of metal!
Old 04-19-2009, 04:21 AM
My MBRP 409 S/S has been thru two maine winters and it has surface rust all over the system except for the muffler which I think is 304 S/S. If you have the money then spend it on S/S but if you want to keep your exhaust options open, change to stacks down the road, then go with the Aluminized steel
Old 04-19-2009, 01:25 PM
I just put my MBRP s/s kit on today and its great. Everything fits perfect and looks good.
Old 04-19-2009, 01:48 PM
I can make you a killer deal on the exhaust when you are ready... and there are a few companies you can run with... and some that will survive the salt a little better... but none the less, the MBRP stainless is a great route to go... PM me or call me at 775-722-8645 if you want some more info
Old 04-19-2009, 03:11 PM
I know its not mbrp but I have a Farm boy diesel 5" exhaust, its made it through 2 PA winters with no rust on it. I painted it with bar b que stove paint last summer and all is well so far.
Old 04-19-2009, 05:54 PM
I have the mbrp aluminum 4" on my truck in minnesota... Had it on for 2 1/2 yrs and no rust at all.... But i do wash the underside of the truck everytime i wash it(Just a quick spray with the pressure washer under) Keep it clean and it will last a long time
Old 04-19-2009, 06:47 PM
Sounds like the aluminumized one is worth a shot then. Thanx!!
Old 04-19-2009, 06:52 PM
i would just go with the AL kit... it will build surface rust but will take a long time for it to completely rust all the way through...
-Raul
Old 04-19-2009, 06:57 PM
-Raul
rauls right, i ran mine this winter with no major rust. any exhaust will rust even within a week, might just be a little spot, but even the aluminum will take a while to rust clean through. imo i would go with the aluminum.
Old 04-20-2009, 03:45 AM
what's wrong with stock ss? cat delete & muff delete and or straight through muffler more than enough flow
