The other day I was pulling my 24' boat and noticed my EGT in the high 800-900 about 60-65 mph. Trailer is about 1200 lbs boat is close to 5000 full of fuel and water. I was running Innovative tow tune. Does this sound about right? For some reason I remember being lower
![]() Just wanna make sure I don't cause problems I don't wanna fix
sounds about right too me.... i wouldnt worry about those egt numbers
-Raul |
Thanks for the heads up Rual, I figured they were about normal but for some reason I thought they used to lower.
Mine often go to 1000 or 1100 pulling the Arbuckle "hills" here in OK with my 9k lb 5er in tow using my street looney tune. With no tune (stock mode) i still see 1000 egts
Damn man i run at 800 on the way to work with no trailer at 2am so i wouldnt worry about those temps
mine run around 700-800 on flat land going 70mph not towing
Sounds normal to me. I wouldn't worry about it...
where do you have the pyro mounted?? manifold or after the turbo?? if its before the turbo than you are fine. if its post turbo then move it to pre turbo
