New to Diesel mods....would appreciate assistance - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-16-2009, 05:27 PM Thread Starter
I am brand new to the forum and performance parts, and I have some questions on what to buy and what some of these acronyms mean.
First:
I've picked out gauges, programmer, and TB exhaust (haven't bought them yet), but why would I want to delete my cat and will I still be able to pass emissions testing?
Next:
Do I bother with an innercooler or is the stock one sufficient?
Last:
What is an EGR delete?
What are studs?
What is the Zoodad mod and is it necessary?
Am I missing anything?
I use it for day to day driving and pull a 14K fiver through mountains 6 or 7 times a year.
I appreciate any and all help.
2005 F-250 6.0 Lariat Crew 4x4 -- only 40K miles and completely stock at the moment.
terawatt is offline
post #2 of 16 Old 04-16-2009, 05:31 PM
zippy557's Avatar
First:
Next:
Last:
What are studs?
Which gauges and programmer were you looking at ??
with an 05 your intercooler is good
depending where you go for inspection you may need the cat, i have a delete pipe in mine and i just replace my cat for inspection when i go.
the 6.0 motors are more prone to blowing the head gaskets so you put head studs in, they are stronger and hold the heads on better, but not always needed
the egr's is another part of the 6.0 that is prone to failure and should just be gotten rid of.
the zoodad is just a hole cut behind the grille in front of the air intake so that you can get more air into the intake since it is pretty solid in front of it
-Dave
'07 F250 FX4 Supercab SB
X3 ID Custom Tunes, ARP Headstuds, S&B Intake, ITP Reg Return Kit, PHP Atlas 80 tuned FICM, Isspro Performax - Coolant, Fuel Pres, Trans and Egt, 4" Turbo Back Straight Pipe, Zoodad Mod, Harley Head Lights, Recon Smoked Cab & Mirror Lights, White Night Back Up Light
zippy557 is offline
post #3 of 16 Old 04-16-2009, 06:21 PM Thread Starter
Thanks for the reply, Zippy557.
I am looking at the Auto-Meter Ultra-Lite 2 gauges (Pyro, Trans, Oil, and Volt meter). I think I can trust the stock boost gauge. SCT X3 programmer and 4" MBRP dual exhaust. Are there any recommendations on where to purchase these products?
What is egr an acronym for and is it a difficult task to get rid of?
I think I will wait on the studs as that sounds expensive. I just found some pictures of the zoodad mod and it looks pretty simple.
terawatt is offline
post #4 of 16 Old 04-17-2009, 01:16 AM
tex25025's Avatar
Oil temp or oil psi?
Either the analog gauge or the factory gauge is off by 2 psi. I could attribute that to eletrical current to either one though. I prefer the range of display on an a/m boost gauge over the factory.
I think most would recommend that you get them from Innovative.
EGR = Exhaust Gas Recirculation. It's not difficult, although the metal is relatively weaker in the up-pipes there, so be careful when you do work around there, very easy to get them cracked.
2006 6.0 King Ranch DRW
Spartan Stage 1 Towing Injectors
Headstuds
Beta Spartan Phalanx
Suncoast Heavy Duty Torqshift Rebuild
ITP Fuel Regulated Return
Straight Piped MBRP 5" Exhaust
64mm Non-VGT turbo
tex25025 is offline
post #5 of 16 Old 04-17-2009, 05:46 AM
Mudvain's Avatar
as for your cat, some say it doesnt affect flow and others say it does. same with emissions testing. however, it will let your turbo be more audible which is probably the best reason yet. if you need to keep your cat, you can always get a delete pipe if it doesnt already come with the system your buying and swap it in when you need it. this one is easy to install as well...
03-06+ Ford 6.0L Powerstroke Diesel Cat Delete Pipe
Mudvain is offline
post #6 of 16 Old 04-17-2009, 06:33 AM
Lubbockguy1979's Avatar
Quoted: 8 Post(s)
Send a message via Yahoo to Lubbockguy1979
From what I have read the best gauges to get if you want to monitor a lot of the trucks functions are as follows egt(exaust gas temp) boost, tranny temp. The next ones are oil temp, fuel pressure, coolant temp. The oil and coolant temp can tell you a lot about the egr system on a stock truck and save you money.
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
Some tuning, gauges and other assorted non factory dodads
Lubbockguy1979 is offline
post #7 of 16 Old 04-17-2009, 12:12 PM
zippy557's Avatar
i agree with tex on innovative, you can deal with them or raul at stealth automotive he may have a package that would work for what you want ... and the x3 comes with innovatives tunes.
-Dave
zippy557 is offline
post #8 of 16 Old 04-17-2009, 12:13 PM
Raul@Stealth Automotive's Avatar
i would def remove the cat.... if your looking for all 3 we can set you up with a package deal that will save you some money... let me know
-Raul
Raul@Stealth Automotive is offline
post #9 of 16 Old 04-17-2009, 12:15 PM
zippy557's Avatar
and there is the guy to help you out ....
-Dave
zippy557 is offline
post #10 of 16 Old 04-17-2009, 03:21 PM Thread Starter
Thumbs down
Oil Temp! I think that is more important, but I could be wrong.
I don't have room for all these gauges, so I can live with a 2 psi tolerance.
Thanks.
MBRP 4" SS TB Dual Exhaust
AutoMeter Gauges (Pyro, Trans Temp, Oil Temp, Volt Meter)
Zoodad Mod
SCT X3 (haven't used yet)
terawatt is offline
