truck shaking - Ford Powerstroke Diesel Forum
Old 04-10-2009, 04:29 PM
Send a message via AIM to BLKF250
truck shaking
i just got done doing the EGR delete on my truck i plug in all my senors and double check my injectors and and at idle and hit speeds the truck shakes more then it should for example my my side mirror shake at an idle iam not sure why anyone got any ideas?
Old 04-11-2009, 07:08 AM
maybe injectors? or dp up against the fire-wall? bump
Old 04-11-2009, 07:12 AM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
do you think it's missing?
Old 04-11-2009, 07:18 AM
how would you test that? click test to see if injectors are firing?
Old 04-11-2009, 07:19 AM
Almostdunfukinwidit
You would need a scan tool that could run a buzz test
Old 04-11-2009, 07:22 AM
would that be a ford scan tool, or would a snap-on or international scan tool work? thanks
Old 04-11-2009, 07:25 AM
and im guessing this buzz test is similar to the click test
Old 04-11-2009, 07:26 AM
Almostdunfukinwidit
Ford, snap on or international tools should do it
Old 04-11-2009, 07:27 AM
thanks for the help
Old 04-12-2009, 11:09 AM
yeah i think its missing because once when i get to 50mph or press the gas slowly its fine but if i get on it shakes really bad but still goes. if i cruise at 50mph once the trans drops back into its lower gear it will shake again. at an idle it shakes to more then usually. but once you take your foot off the gas of man its smooth like no other thats why i think its missing..... Ive recently had the dealer put in 4 new injectors and a new FICM and i double check all my injector clicks and disconnected my FICM and reconnect it and it still does it......if i had to pick something else othere then missing that can go wrong i would say fuel filters havent change them in a while and i couldnt tell you the last time i empty that water separter from the fuel pump... anyone got any ideas whats up?
