heavy towin upgrades - Ford Powerstroke Diesel Forum
Old 04-04-2009, 08:54 AM
Send a message via AIM to zachs04250
Post heavy towin upgrades
it been a while so this topic may have been coverd so im not wastin time direct me, anyway i have a laundry list in my head of upgrade i want to get done trans rebuild w red eagle clutches and 5 disc converter have the rear end upgraded to a 4.11 gear and new wheel bearings, turbo is next been lookin around but have no idea what to go with vgt-ss is lookin good but have found cheeper and some kind a highbread ( if someone can inlighten me on that one? ) been lookin on inovative and elite at what they offer but discripions suck. on a side note im living in phoenix,az now and is there a shope around here to have studs dun and possable injectors, dont mind traveling i dont have a lift to pull a crew cab, tx, zach
Old 04-04-2009, 11:57 AM
If you do the studs you will also want to do a full EGR delete. You should also do a regulated return and if you have the heads off think about the head coolant lines to help keep the heads cool. (only $150) I got mine from Elite
Old 04-04-2009, 12:39 PM
Location: Savannah, Tenn. (over 100 miles east of Memphis)
I see in your signature that you jave an Edge tuner. You need to chunk that and get a customed tuned SCT.
Old 04-04-2009, 12:54 PM
Location: not to far from the city of "Brotherly Loved"
If your doing alot of heavy towing I would also suggest the Air Lift rear setup........Just my $0.02
Old 04-04-2009, 01:26 PM
i have the firestone air bags on the rear and a 20k curtis 5er slider already, just want reliable upgrades for pulling a 18k plus trailer every weekend
Old 04-04-2009, 01:31 PM
im not looking for crazy tuning or power, i have no beef with the edge have had it for over a year and works great
Old 04-04-2009, 02:24 PM
If your looking at an aftermarket turbo(and depending on size be default looking for a/m injectors) you'll need something that has custom tuning abilities otherwise your truck will drive like crap. Edge won't cut it.
Old 04-04-2009, 05:57 PM
NOT looking to go crazy and i dont believe i need a tune to run a bigger turbo, if you call a 200 cfm increase a bigger turbo,
Old 04-04-2009, 06:02 PM
Almostdunfukinwidit
Yes you will need custom tuning to go with the bigger turbo
Old 04-04-2009, 06:34 PM
I don't care if you get the ATS Aurora 3000 turbo(which is a smaller turbo then our stock one), you will still need custom tuning.
