Gauges Installed In Dash, Lots o' Pics! - Ford Powerstroke Diesel Forum
Old 04-03-2009, 07:16 PM
Well, I finally settled on the ISSPRO EV2 gauges; pyro, fuel pressure, and boost. I installed the pyro gauge in a single gauge pod under the pillar handle. Fuel pressure and boost went in the dash on either side of the steering column. Below are pics and descriptions. I'm really pleased with how the dash gauges turned out, definitely better than I expected.
First off, I used some mesh cable sleeving to make the wiring harnesses all purdy:
Next I installed the sensors, pyro in the driver side manifold:
Boost in my Banks elbow:
Fuel Pressure in the test port of the fuel filter housing. This actually cracked my housing and it now has JB Weld sealing the leak; GOS has pulled this fitting from their shelves now because of this problem, great service though (Thanks Aden!). I have another housing in the mail. I added a 45 degree fitting to keep the harness away from the upper radiator hose.
Here's the single gauge pod and pyro wiring, more sweet sleeving:
Pyro gauge installed. I liked the non-color-coded gauge, its a bit cleaner looking:
Behind the dash bezel... The right side needed a little Dremel action to make room the the gauge to insert, left side there was plenty of room:
I used a 2" hole saw and drilled from the back with the drill in reverse to make it slower and cleaner:
Finished product. The ISSPRO gauges match great and look almost stock. I am very pleased to say the least.
Big thanks to Aden at GOS Performance for the great deal on the gauges and excellent customer service. Also, thanks to Michael at ISSPRO and CSIPSD (both on The Diesel Garage). Feel free to ask any questions about the gauges or the install!
Old 04-03-2009, 07:19 PM
Nice Job!!! Thats a good idea in the dash! I am not wanting to have a pillar mount but dont wanna spend the money for digital gauges either yet...
Thanks for the ideas!!
Old 04-03-2009, 07:24 PM
285,261,190
that looks awesome, great idea
Old 04-03-2009, 07:28 PM
i like the idea but how functional is it..how it is while driving? or when in Drive. you took the pic while the shifter was in Reverse.
Old 04-03-2009, 09:40 PM
Pretty nice...............
Old 04-03-2009, 10:15 PM
I can see the fuel pressure gauge fully, the boost gauge is only covered by the shift lever for the top 1/4" or so. I'm not that concerned with boost, just want it there to diagnose if something is wrong. I was mostly concerned with EGTs and fuel pressure, and keeping my handle
Old 04-03-2009, 10:24 PM
I like
Old 04-03-2009, 11:39 PM
this is an awesome idea!!
Old 04-04-2009, 12:10 AM
what size brass fitting did you use for the fuel pressure sender? i was going to get one of the ones from ITP but if i could save 50 bucks that would be great..
Old 04-04-2009, 01:47 AM
Great idea and VERY nice job!!!
