ATS Head Coolant lines - Ford Powerstroke Diesel Forum
Old 04-01-2009, 05:32 PM
Has anyone else done this? When I blew my head gaskets the diesel shop recomended that I have the heads drilled tapped and return lines to the water pump.
Old 04-01-2009, 06:47 PM
your sig said you already did this whats up with that. i wouldnt do it you dont even need it. the only reason you got hot is cause you had a blown headgasket. if you do it go with elites they have more experience with the 6.0 than ats.
Old 04-02-2009, 01:23 AM
I had Elites lines put on in Jan. when my HG blew and they seem to be helping. They are one of those things that I think are a cheep mod to help with the life of your 6.0.
Old 04-02-2009, 05:35 AM
I already did this because the shop said it was a good idea. But since I had them done I have had a lot of workmenship problems with the shop, They had the heads off 3 times and it went back 6 times before they got it running correct over a 2 and a half month time!!! and 3,500.00!! Since then I had herd of the shop giving guys more problems and selling things that people don't really need!! Just trying to find out if i got ripped off!
Old 04-07-2009, 04:20 PM
there worthless, if you have ever seen the coolant inlets and outlets to the heads(huge), youll never even think about getting them.
Old 04-08-2009, 02:45 PM
Well said Brody.
Old 04-08-2009, 04:15 PM
Originally Posted by FionaThe02PSD View Post
Well said Brody.
Old 04-08-2009, 07:05 PM
So I guess I kinda got ripped!
