Confused about my turbo, help me understand please? - Ford Powerstroke Diesel Forum
Old 04-01-2009, 05:36 AM
Hi,
I know you guys must be tired of my turbo post, but I am unsure if once the VGT on 2004 is disassembled, it requires going into the vehicle's ECM and reprogramming it.
I included a great step by step maintenance that someone hooked me up with. The part I am confused with is the very bottom where it states specific technician procedures after the cleaning. PLEASE HELP if you can.
Thank you
http://www.forddoctorsdts.com/articl...icle-06-05.php
Old 04-01-2009, 05:46 AM
i have cleaned mine lots and never done anything special afterwards. i have a early 03 with a stock turbo. the only thing i do is pour a little oil in the hole on top of the turbo before i bolt the oil feed pipe back on.
hope that eases your mind
clarence
Old 04-01-2009, 07:00 AM
Very Cool.
Did you replace the gaskets and o-rings (not sure if I am accurate on this one) whn you did it?
Any chance you have the part #'s for the items I will need to do this?
Thank you very much
Old 04-01-2009, 07:37 AM
well, technically you are supposed to replace the o-ring on the drain tube every time but i didn't. and usually you can re-use the gasket for the feed line. just lube the o-ring good when you put it back on so as not to tear it.
clarence
