Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 02-01-2006, 07:51 AM
redseal199 redseal199 is offline
ARP Head Stud Kits!! for 6.0's
Jegs Sell them for 381.99 2 week delivery time if they can get them. No one has them and i need them as i my sick o is at the dealer due to head gasket failure. Part # 250-4202 hope this helps guys.
Old 02-01-2006, 11:21 AM
stomper2 stomper2 is offline
I've been thinking of this also. Does anyone know if they are a pain to put in?
Old 02-01-2006, 12:07 PM
Patrick Patrick is offline
Well, Im pretty sure you have to remove the Heads to do it. So, that would suck for the average guy I think. Lots of tubes, wires, and other things on top of that engine. I wouldnt say its impossible. I just sent an email to our supplier to see if we can offer those at a better price than Jegs. I know they Retail for over 700 bucks.
Old 02-01-2006, 02:57 PM
KCS250 KCS250 is offline
Any one know how much boost the 6.0L could/should 6.0L handle w/ studs and the latest head gaskets?
Old 02-01-2006, 02:59 PM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
I've heard that with head studs you can run quite a bit of boost, like 60lbs or more.....but if you get too much then they suggest o-ringing too....
Old 02-01-2006, 04:32 PM
mschn99 mschn99 is offline
if you are going to put the studs in yourself....you woud have to pull the motor...i lift the cabs......either way, there is an extreme amount of torque needed to hold those heads down with the high compression of that motor...and you have things to think about like the egr cooler stuff, etc. i would reccomend taking it to someone. also, i would reccomend buying the ford intake gasket set....it comes with pretty much all the o rings and gaskets needed EXCEPT the oil filter housing lower o ring and the head gasket parts. make sure to change your orange egr cooler hose in the valley with the updated blue one to prevent leakage in the future......any questions...let me know....Marc
Old 02-01-2006, 06:28 PM
Marc, we are supposed to get new catalogs from BD diesel anyday. They are supposed to come out with an intercooler for the 6.0L. As far as I know they are the only ones talking about it. Is it needed? I've heard lots of people say that it already has a very good intercooler. We sell lots of them to guys with the 7.3L from banks.
Old 02-01-2006, 06:42 PM
banks is the only aftermarket intercooler ive seen on the sick-0 so far....and yes, ive replace probably a dozen that have blown the side tanks off already, and most of those were just on stock vehicles that tow a lot and just use the higher boost more........i would reccomend it....
Old 02-02-2006, 05:14 AM
Trashdawg Trashdawg is offline
On the 03 and up Dodges, and D-max you can get away not pulling the head when you do studs. You just replace one at a time.
Old 02-02-2006, 10:22 AM
Yeah....well look where the head is on a dodge!
