Crank Case Vent Mod - Ford Powerstroke Diesel Forum
Closed Thread
Old 03-29-2009, 04:21 PM
Crank Case Vent Mod
I just Installed the kit from Stealth and NCHornet and it went on easy and with no problems. I wish I could have mounted the tank a little closer to the motor but I think it will be ok where it is. Its directly under the driver door on the frame could have went further forward but I would have had to cut a cab brace and didn't really want to get into that. All and all a excellent kit. Raul and Kevin did a really good job on getting this out,it keep your driveway clean not to mention your intakes thanks guys!!! I had to have 12 ft of hose instead of the instruction 8 to 10.
Old 03-29-2009, 05:49 PM
could you post some detailed pics by any chance? i got mine and im just waiting on my next day off to install and the pics would help out alot.
Old 03-29-2009, 06:05 PM
What doed the kit do?
Old 03-29-2009, 06:14 PM
please dont post detailed pics in process of getting a patend and dont want to risk anyone taking the design.... if you do send pics please do so through PM's
Old 03-29-2009, 06:16 PM
285,261,190
beat me to it raul, I was just typing that
Old 03-29-2009, 06:20 PM
Old 03-30-2009, 05:05 PM
No prob Raul i was just looking for some help for when i do my install. Sry bout that.
Old 02-22-2010, 08:03 AM
Opening up an old thread...
Anyone ever try using an air compressor air filter to use as the oil catcher/filter? Just hook it up in reverse direction and have a return line to the intake. Think it would work? It would be easy to check on levels cause it has a see though design and easy to change. The air stone shouldn't clog either if it's set up in the reverse flow. Whatcha think?
Old 02-22-2010, 02:30 PM
how much for the kit, raul post a link please
Old 02-22-2010, 02:39 PM
here you go: CCV Mod
Closed Thread
