Gutted my kitty this AM!!!
Gettin ready for the tuner so I gutted the kitty, now I need to order my muffler delete pipe!
Didn't notice much of an improvement performance wise, prolly cause the stock muffler is still intact... I guess the muffler is just as restrictive as the cat... ![]() Question... If I order a tip, what size fits over the 3.5"?? 4" OD or ID??? Or something different?? |
i got a 4" ID from magnaflow and it was a bit big on my 4" piping
Guess I am looking at a 3.5" inlet??? I am ordering from puredieselpower.com (also ordering the muff delete there) so I want to make sure I get it right...
yeah the 4" will be so big on stock piping you wont be able to crack a bead, unless your going clamp on then you might get it to work, i would go with a 3.5" diameter to 5-6" out if they have that, are you getting full exhaust anytime?
Maybe... Depends on how much I like 3.5" stock straight pipes!
All I see is 3.5" weld on tips... Wanted to clamp em, but my bud has a welder so either way!
Youll like the stock straight pipe!! but if your planning on a tuner anytime, i would toss out the extra bucks and get the full t/b kit, your stock downpipe is pretty restrictive with the unnecessary bends and kinks in it, she needs to breath!!!
As for the tip, only advantage to a clamp on that i can think of is you can take it off to polish and clean it? but i personally dont like the clamp on look at all, weld on looks so much more clean!! |
That's why I am modding the exhaust is for a tuner... Read there isnt a great deal of difference between 3.5 and 4" systems as long as the muff/cat are outta the picture...
not tons no, just a little lower egt's but youll be fine with the 3.5" straight pipe, and you will LOVE the sound!!
i cut my cat off & did not nottice much diff but then i cut my muffler off and ran exhaust in front of rear tire with a 5 inch tip sounds awsome.
Sounds like a jet taking off, the muffler realy woke up the turbo. (All straight pipe is the way to go) plus its cheaper |
I wish there was a hanger right after the muffler so I could dump it right before the axle... I suppose I could do that with my buddies help too!
