2 stroke oil
I know its done in the cummins all the time, I ran it in mine, what about the FORDS........
Why now, it burns right? I'd do it but I already have some oil in mine. Well usually.
I use it all the time, 1oz per gallon of fuel. Make sure you use the TC-W3 2-stroke as this is the ashless type. Makes a huge difference in engine/injector noise.
Same here as above , But no!!!
I run it in mine also quiets it down a good bit I put 1 quart every fill up so bout 1 oz a gallon
What is the real benefit of putting 2 stroke oil in your fuel?
It lubes the injectors some and quiets them down. You would get the same benefit using stanadyne or diesel kleenn. Plus with the additive you would get a boost in cetane
Wow I never thought of putting 2 in my diesel. So you guys recomend TC-W3 2-stroke. Is that the best to use???
It has to be ashless whatever you use
OK thanks. why?? I can use what ever oil??? I'm not going to buy the cheapest stuff but I'm still wondering...????
