Boost sensor?? - Ford Powerstroke Diesel Forum
Old 03-20-2009, 05:06 PM
Boost sensor??
Where is the best place to mount a boost sensor from autometer. I have mine mounted in the bung on the intake elbow and the gauge says I've hit 42 lbs of boost! Is that even posible with a stock turbo on a 04, cause I didn't think it was.
Old 03-20-2009, 05:40 PM
Bump>>>>>>>>>>>>>>>>>>>>
Old 03-20-2009, 06:02 PM
i dont know..mine on the performance canned tunes i hit 35 psi
Old 03-20-2009, 06:38 PM
Powerstroke Techie
stock should run about 20-24
i would take it at the same spot as stock. there is a black hose on the passenger side of the intake that runs up to the map sensor. that's the stock boost sensor.
Old 03-21-2009, 06:23 AM
Feedback Score: 5 reviews
I would leave it in the bung..
42 is possible with a spike..it wont do that consistently.
If you tap into the map sensor (as said above) your boost gauge will bounce.
Old 03-21-2009, 07:04 AM
yeah i agree with Adam, dont cut that map sensor line.
dont ask how i know....
Old 03-21-2009, 07:35 AM
thanks for your input guys appreciate it.
Old 03-22-2009, 04:15 PM
Powerstroke Techie
Hmm. Had no idea it would bounce. Good to know though.
