duramax compressor? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-19-2009, 10:54 AM Thread Starter
dill's Avatar
Lightbulb duramax compressor?
Ok, been looking and researching and asking whoever will listen, but nobody will give me a good answer or proof. Will the compressor side of the LLY and up duramax turbo work on a powerstroke? I know they will bolt up together, but is the clocking and mapping going to work with an early 03 hot side. and don't say just put a non vgt on it. I will NOT put a normal turbo on this. The duramax boys are putting almost 600hp down with stock turbos, and some are modding them and getting better drive pressures and flow. don't know if it is because of the vein sensors or cooling, but they seem to like them. I like the vgt but it needs to flow more. If this doesn't work I might throw another turbo on top of this and make it a compound. Fleece Performance has a 71.5mm Cheetah that is a 37 sized turbo. I believe they have a 94mm exducer, Garrett has 64/94 AVNT but that might be a 40 sized hot side. Anybody played with this or know where a super cheap duramax turbo would be?
2003 f250 lariat 6.0 auto cc sb 4x4
leveled, 20x12 chrome hostages, 305/55r20s, 5" stacks, SCT livewire, billet grilles, custom vgt / s475 compound, custom built headers, ported heads, 6.4 valves, Hamilton springs, reworked pistons, delta cam, Florida converter, custom built 5r110, painted frame, chrome metalflaked valve covers oil pan and drive shafts.
dill is offline
post #2 of 14 Old 03-19-2009, 10:59 AM
SuperdutyKing's Avatar
Location: Savannah, Tenn. (over 100 miles east of Memphis)
Wish I could be of help or had something of an answer, so here's a
Cory
1995
F-250 XLT
7.3 Powerstroke Lapis Blue Metallic SuperCab ZF5 3.55 2wd Long Bed 275k miles
3.5 from the downpipe to stock 6.4 muffler, 43367 diy intake.
1993 F250 XL RCLB Turbo 7.3 IDI zf5 2wd 223k miles; 5 inch exhaust & tint -sold-
2006 F350 Lariat Harley Interior CCSB 6.0 Powerstroke 5r110 4x4 43k miles; SCT, EGR delete, ARP studs, tint, & 5 inch exhaust -sold-
SuperdutyKing is offline
post #3 of 14 Old 03-19-2009, 11:09 AM
dukcaln's Avatar
I was thinking about this the other daym so here is a bump for someone to let us know.......my buddy makes 625hp with race allison trans, 5" exhaust, air intake and efi live.....thats it...hpw sick is that.............. stock inj stock turbo stock fuel sys
04.5 LLY DURAMAX. EFI, AIR, FUEL, TRACTION AND MORE! POWERSTROKE SLEEPER SLAYER!!
dukcaln is offline
post #4 of 14 Old 03-19-2009, 11:13 AM
jhaddox's Avatar
Send a message via AIM to jhaddox
common rail fuel system vs huei...their just easier to get power out we cant flow the fuel they can as easily
08 ECSB 6.4
MPD, GOGO, No Limit, Rudys, ARP, PMF, Innovative, AFE, Recon, Fuel, Nitto, Bilstein
jhaddox is offline
post #5 of 14 Old 03-20-2009, 10:00 AM Thread Starter
dill's Avatar
Yeah that is true but with a little bigger injectors and a big tune it will smoke like crazy at wot. If it had more air it would make more power.
dill is offline
post #6 of 14 Old 03-20-2009, 10:04 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
I havent even heard of this!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #7 of 14 Old 03-20-2009, 11:58 AM Thread Starter
dill's Avatar
jhaddox, I see you have a spartan vgt-40. Do you like it? and do you happen to have any specs on it? is the compressor a modded powerstroke or is it a different garrett housing. This is another turbo nobody seems to know much about.
dill is offline
post #8 of 14 Old 03-23-2009, 02:24 PM Thread Starter
dill's Avatar
maybe I need to look harder for dmax turbo. I wish Fleece would email me back.
dill is offline
post #9 of 14 Old 03-23-2009, 02:28 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Dmax turbo is not gonna make a difference for you. Get yourself a set of 190's and either run them with the 03 stocker or upgrade to a modded vgt or II 62/70
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #10 of 14 Old 03-24-2009, 08:40 AM Thread Starter
dill's Avatar
that's the plan. 190's, modded 03 turbo, and some giggle gas.
dill is offline
