Chug?
I put stage one injectors from Hypermax, the truck idling and driving has an intermitting chug it appears come and go. So far i've only have driven only about half of a tank. I've heard its takes about 1 to 2 tanks to get it out and bigger than stock sticks its more apperaent than on stockers. Is this air in the fuel system still? How long does it take to get out of the system? And if there’s air in the system is this the symptom for it?
Anyone????
Anyone have any input?
did you get your chip retuned for your injectors?
you wont need to retune for stage ones, if you went half a tank, it should take about 100ish miles to get all the air out of the system..the chugging, shaking feeling could be an injector issue. did you install them yourself?...what did you tq them too?...did you clean out the holes/threads that the injector retainer threads into?
when you first start the truck up does it smoke at all? |
I installed myself and belive i torqued them to 25 ftlbs i think i reall didnt clean the hole where the retainer bolts went into.
The truck really doesnt smoke when i start it up but it has a haze |
My truck acted up after we put Hypermax stg 1s in it and then had to put another set in the truck because it was shake going down the road on and off. We finally got it lined out after 2 sets of injectors. Then a few wks later the FICM went bad.
Jake |
like 2fast2reid said he got ir right the 2nd time. like i said i dont know how hyper max does it but remember some places are using core charges to build injectors, you could have maybe a bad one..if you know anyone with AE you could have a contribution test done and see if that tells you anything. or maybe have the dealer do a buzz test, mainly the buzz test is for spool valves but who knows..i would also check and see if you see any oil coming out of the glow plug holes. |
Yea you do. There is no way that the truck's computer is going to be able to account for the extra 15mm^3 of fuel that is there by no blow off valve on the injectors. Second, I ran a tune that was made for stock injectors and the truck ran like crap and I have stage 1s, not performance stage 1's either(although technically they supposedly flow the same amount). He'll need to re-tune. |
my truck did the same thing when I loaded my old extreme street tune with my new injectors and fuel system. Seems like it only gave me a problem when i would start it up in the morning after the truck sat. Factory torque is 26ft lbs. I believe elite ask's to torque theres down to 36ft. lbs but every companies diffrent. Evans right about oil being in those holes. My truck made it about 150 miles and this happaned
I have also noticed under normal driving conditions the truck will idle diffrent when you get out of it but thats just do to the bigger injectors.
