WHAT TUNE SHOULD I RUN WITH??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-08-2009, 12:51 PM Thread Starter
Spoolin05Stinker's Avatar
Location: not to far from the city of "Brotherly Loved"
Question WHAT TUNE SHOULD I RUN WITH???
Okay just have a couple of questions for you guys. Just took my truck in to the shop due to a smoking issue, which turned out to be a faulty Ficm, not a problem. Well they gave me the most recent updated flash file but when I went to go load my Sct I realized that my strategy was different so I stopped there. Dropped Eric an email to see if he can help... My main question is which tune should I be running?? I have a ARE contractor cap on my truck loaded with screw guns, miter saw, table saw etc etc...My guess all tools combined weight is 400-600 pounds, truck cap may weigh 200 pounds not sure totaling 800 pounds, also tow a low boy 6x12 dump trailer.When not towing is it safe to run the extreme street with the weight?????
2005 F-250
4"Mbrp With Cat
33x12.5x17 MT BAJA MTZ
Autometer Boost, Egt, Trans gauges
Green Drop in Air Filter
ARE DCU Series Cap Trucks gotta make me Money
MSD Daswhawk for the other parameters
Spoolin05Stinker is offline
post #2 of 4 Old 03-08-2009, 12:54 PM
jamstoyz's Avatar
sure just keep a eye one your gauges like your egt's. i have towed a 10k camper with dj's looney tune. just gotta watch your egt's thats all. with no trailer, i wouldnt be worried at all.
05 Single Cab Short Bed
*03 Turbo*Stroked Injectors*AFE Stage 2*Small mouth Intake*SCT With Eric's Extreme Race*4.30 Gear*Best ET 13.5@99MPH*
jamstoyz is offline
post #3 of 4 Old 03-08-2009, 01:09 PM
tex25025's Avatar
I would also suggest you keep an eye on your tranny temp gauge and either ECT and/or EOT if you have those as well. Running a race tune with extra weight and a trailer can add extra temp degrees on there and you could have good EGTs but be running hot in other areas. Although I would not advocate using a program with a tranny program designed for racing applications when towing, I would keep an eye on those temps to make sure. Ultimately, it would be better to have a tow program, but it's your truck.
2006 6.0 King Ranch DRW
Spartan Stage 1 Towing Injectors
Headstuds
Beta Spartan Phalanx
Suncoast Heavy Duty Torqshift Rebuild
ITP Fuel Regulated Return
Straight Piped MBRP 5" Exhaust
64mm Non-VGT turbo
tex25025 is offline
post #4 of 4 Old 03-08-2009, 01:21 PM
AFBLUE's Avatar
Ditto, Personally I load the tow tune when I am loaded more than 4k over stock.
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
