Pre SCT Mods
Alright, so yall have convinced me to get an SCT Livewire tuner. The only question I have is should I do anything else with my 6.0 before buying it? I currently have a K&N air filter, 4" cat back exhaust, and the kitty's missing.
Thanks guys. |
you going with the windshield mount? i'd use standard pillar style guages. Raul brought up a good point in another thread about it getting stolen being mistaken for a gps
ya go with a x3 with custom tunes and get gauges seen a livewire kinda big and bulky and if the tuner goes so does your gauges and i dont like that myself to much.
yah im not a big fan of the livewire or any 1 unit pieces...
plus the livewire is bulkly an easily stolen... and digital gauges are not as accurate as analog gauges... me personally i do not like the livewire... if you went with a X3/ gauge combo you would be paying less then doing the livewire and the egt probe let me know if you have any questions about it -Raul |
depending on your cash flow, i would get the gauges like the others said and also do the egr delete and head studs. definately get custom tunes too.
You keep on saying that, but you've never answered my question on do you use long or short sweep gauges. The reason why I ask that(yet again) is that you have more guessing on short sweep gauges then long sweep(and I do have long sweep gauges). The only difference that I have seen using the DashDAQ and analog gauges is 2-4 degrees higher on the DashDAQ for TFT. All the others are spot on with everything that I've seen and I have copious notes on that. |
Also, technically speaking it's not digital gauges that I think you have a problem with, it's the OBD-II gauges that you have difficulty with. There are digital gauges that use external probes but they just have a digital display. I might be wrong, but if your just talking about digital guages period then you would have that issue as well. Normally I wouldn't be this adament on knowing, but given that my comparisions between the DashDAQ and the long sweep analog gauges that I have, the only difference was the 2-4 degree TFT difference and the DashDAQ was on the hotter side(which I would rather have it be on the hotter side then the colder side if it was going to be a little off, but 2-4 degrees is neglible in my opinion). Also I'm not disturbed by the difference in TFT readings is because if your gauge is in a spot that you don't know exactly what that blank spot means or that tick mark means, you could be off in your judgement 2-4 degrees(or more if it's short sweep and in a blank spot). All the other gauges that I used were on the nose(EOT and ECT being the more important ones I concentrated on). Couple that with the fact that you never told me how you made those comparisions on your own(if you did, but I'll give you the benefit of the doubt on that one), I can't give as much credence to your statement especially since I've tried several times to find out what evidence you had that lead you to your opinion and no response. Now, I won't ask you again how you came to that conclusion since you obviously don't want to mention, but I can't help but question it without knowing your train of thought when it differs from my own observations. Last edited by tex25025; 03-08-2009 at 08:09 AM. |
Thanks guys. Sorry i was without internet for the last week. The thing with the gauges though is they stand out, and they aren't something that you can just take off. Plus I was thinking about trying to mount it down lower around my radio or something, so it's not as visible. I kind of want inconspicuous power, cause if i pull up next to some one, and they see the column, they know i have something. Same goes with cops.
2006 Ford F350 4x4 - Beta 6.0L Spartan Phalanx Tuner |
Yea, that's a nice setup you have there Tex
