So....Now What ?
Got HG, ARP Studs done by dealer warranty. Note on bill says he re-programmed the FICM because runs rough when cold
Loaded the Ext Street tune back on, all good except it seems to starve for fuel @ high rpm -hesitate on the jump- and max the boost @30 - was closer to 40 before the job - What to do?
I had the same thing....he probably changed your strategy.
Re-check it. You'll probably need new tunes. |
Rechecked Strategy - it is same as given to Eric for tunes. Did notice an added line under tranny strategy.... ARZ2AL01
Also - looks like 3700-3800 RPMs is the starving point |
So looks like the code is related to the FICM.....
"If the FICM contains one of the following files then it has already had the Inductive Heat calibration installed: " ARZ2AH00 ARZ2AL00 ARZ2AL01 |
you need to send the tuner back to where you got it and tell them ford reflashed your truck.
FICM won't change strategy, or shouldn't. the ARZ2AL01 is the head cali.
Email Eric. He'll probably just adjust/update the tune. |
Got it from Raul/Stealth, Tunes By Eric @ID
Just get in touch with Eric and he should be able to get you straightened out.
The same thing is happening with my truck. I had the studs, EGR delete, head coolant lines and a fuel crossover line put in. I tried my old tune (ASE) from Eric and it runs great (with the CE light on) but the new tune with EGR daleted dos now pull as hard and startes to miss at about 3,500-3,600 rpm's.
That's the silliest thing I have ever seen. The tuner itself doesn't care about strategies. It's the tune itself. Stellar advice dude. Boggsie, it's time for new sticks and a bigger turbo, slap a FASS 150 on it, have Eric do his thing to the FICM and do fresh tunes, and throw a set of 4.30's on that puppy. If you still have some cash after that let me know lol. Last edited by PGreenSVT; 03-08-2009 at 09:19 AM. |
