tommorows project - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-05-2009, 02:46 PM Thread Starter
jay diesel's Avatar
tommorows project
Just got my 4" mbrp tb off roadexhaust w muff delete pipe. wish I could put it on now but it is dark. Any suggestions before I tackle this tommorow.
2007 f-250 crew cab lariat fx4
4" Turbo Back mbrp with a missing kitty cat
edge insight cs
SCT tuned by eric @ innovative diesel
ARP studs
Bullet Proof EGR cooler
banks power elbow and cac tube
jay diesel is offline
post #2 of 4 Old 03-05-2009, 02:48 PM
Raul@Stealth Automotive's Avatar
shoot some wd40 on the DP clamp.. that thing can be a ***** to get off sometimes...
and do not try and take the exhaust out in 1 piece.. its soo much easier to just cut it in 3 or 4 pieces and taking it out that way... cut it right under the dp where it curves to teh back so that you can grab the DP and wiggle it around to pop it off the turbo housing...
if you need any more help just let me know
-Raul
Raul@Stealth Automotive is offline
post #3 of 4 Old 03-06-2009, 03:28 AM
SC Premium Member
Rattler-FX4's Avatar
Quoted: 2 Post(s)
Agree on the cutting a few times. On the DP, cut it as far up as you can - it makes it SOOOOO much easier to get out. Also, the stock DP has a holding or alignment tab on the top that helps hold it to the turbo so it's a lift and then pull or work it's way out the bottom. I'll edit later this morning and add a snap shot of this. There's also a bolt sticking out from the firewall that helps hold the foil liner on - simply tap that back towards the front of the truck to ease removal of stock DP. Just installed mine this week.
Take care
............Greg
2006 F250 CC FX4/Lariat * Chrome PKG * 2011 F250 8-spoke wheels * Toyo OC ATII 35x12.5x20 * MOD's (Zoo-dad, Fog light, Homelink, High Idle, THRC) * 4" TB MBRP * SCT w/Innovative Diesel's Xtreme Street Tune * Blocked EGR cooler * Isspro gauges * Dieselsite's Coolant Filtration System * RCX 3" Lift w/2.2 Shocks * RCX dual 2.2 steering stabilizer * * lots more coming ...
Rattler-FX4 is offline
post #4 of 4 Old 03-06-2009, 03:32 AM
<-Day Of Fail now SOLD
POWERED SPARKLESS's Avatar
-Raul
If you have a 4' DP it might take a little convincing to get it back up there. And before you clamp everything down tight get all the pipes lined up how you want them and start at the DP and move back.
Tyler T
Sold 2 April 2011
To some lucky SOB
2004 6.0 CC FX4 Lariat
It had all the right things missing or added
Originally Posted by DunesRunner08 View Post
IF YOU DO NOT STAND BEHIND OUR TROOPS....FEEL FREE TO STAND IN FRONT OF THEM!!!!!
POWERED SPARKLESS is offline
