WHAT is the easiest way to get rid of the stock muffler?
like the question in the title says, what is the easiest way. Some simple, to give me the sound I want until I buy the exhaust I want.
Does anyone make a delete pipe to fit the stock size exhaust? |
I see a sawzall in your future, unless you got a muffler shop that will do the work.
Just disconnect it at last clamp before the muffler, and put a turn down on it. Thats how mine is! Little raspy at 2700 rpm, but sounds like a V8 with flowmasters at WOT
I used a Cut Off wheel to get mine off and installed a 3.5" SS flex. And pulled and cleand out kitty, re-installed and love the sound at idle and you can really here the turbo when you get on it
knew that was coming! Yep, chop it off before your stock muffler, and if you wanna go all out, pull off your cat, and punch it out takes about 15 minutes, just take a pry bar or a piece of tubing and hammer away untill its clean. For a finished look you can throw a turndown tip on it.
all i did is cut at both ends of the muffler , got that out and installed a piece of flex pipe the same lenght and it sounded pretty good... doesnt sound good on a manual like it does on an automatic !!!
I found an MBRP piece for like $60 to put in there, works for me. It just replaces the muffler. cause I'm really picky about exhaust, so I have to figure out what I really want before I commit to a whole system. this'll just give me close to the sound I want. And, as for the cat, the guy who had the truck before me had it taken care of. Looks like he had a muffler shop cut the ends off the cat and weld a piece uf exhaust tubing between them. Works well enough for me and it doesn't leak, so perfect.
sweet, got it done!
