3.5" vs 4" exhaust - Ford Powerstroke Diesel Forum
Old 03-01-2009, 11:38 AM
3.5" vs 4" exhaust
I have found inexpensive was to straight pipe my stock exhaust. I am gonna see a big difference with that vs a 4" system?
Old 03-01-2009, 11:40 AM
You should be fine with the 3.5". Most say the big restriction is the cat and muff.
Old 03-01-2009, 11:43 AM
a truck
Yeah straightpiping the stock is definitely the cheapest route, you wont see a real difference if you go with a 4", the mendrel bends and everything are just nicer
Old 03-01-2009, 04:10 PM
Cool we're talking $100 vs $250 for a 4" kit. I need to be cost effective with the way things are going.
Old 03-01-2009, 04:12 PM
a truck
Id say just go with straightpiping the stock exhaust for now then
Old 03-23-2009, 07:41 PM
This is the route I am going unless tuning my rig will require 4" system to lower egts!!
Old 03-23-2009, 07:46 PM
6.0 are mandrel bent anyways. 3.5 would be just fine for a mild stock mod. The EGTs wont get crazy and would only be a small difference in hp between 3.5 and 4"
What is 100? the muffler delete pipe is $65.00
03-06 Ford 6L Powerstroke Diesel Stock Muffler Delete Pipe
Old 03-24-2009, 05:46 AM
Oh snap! It doesnt have to be welded?? If thats the case I can do it myself!!
Also, I am getting 150.00 shipped for the muffler and cat delete from that site?? Any cheaper sites to look at?
Old 03-24-2009, 12:27 PM
Yeah you just have to cut out the stock muffler because thats welded in, then just muffler clamp it in.
The cat is a direct bolt in piece, no cutting. But personally I would just punch out the cat if you are never going to use it again.
Old 03-24-2009, 12:30 PM
So just gut it and keep the cat housing in place?
