Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 03-01-2009, 11:42 AM
05 F350 6.oL 05 F350 6.oL is offline
Smile BLOW OFF VALVE!!!
if any one has a blow off valve on their truck will you post your pictures up here
i need to see how mine should look when i put it on thanks!
Old 03-02-2009, 06:27 AM
help me please!!
Old 03-02-2009, 01:26 PM
musclecarboy musclecarboy is offline
Is it even possible on a diesel? LOL
Isn't a blowoff valve for when a gas engine is in high boost then you let off the pedal and the throttle plate closes, causing all the extra pressure.
Old 03-02-2009, 01:29 PM
strokerguy strokerguy is offline
yea it is possible but they are not need
Old 03-02-2009, 01:31 PM
StrokedCoastie StrokedCoastie is offline
A B.O.V on a diesel cures the reverse pressure on the turbo, same as gas, just a little different since a diesel doesn't have a "butterfly". The reverse pressure does bad things to a turbo, it tries to stall the turbine.
Old 03-02-2009, 02:38 PM
szyd szyd is offline
This is.pitamarillo84 set up.
Old 03-02-2009, 02:44 PM
yosh30 yosh30 is offline
heres a vid on youtube if you havent already seen it..
YouTube - 50mm Blow Off Valve.... On a 04 Duramax Diesel LB7
i think it would be cool sometimes, but might get a little annoying..maybe only cool at the track. but that setup above is pretty sweet, did he just weld another pipe on to the banks i/c pipe? looks pretty simple
Old 03-02-2009, 08:07 PM
!!!PainTrain!!! !!!PainTrain!!! is offline
TED NUGENT FOR PRESIDENT
I don't think you can put a BOV on a VGT turbo, it needs to be a fixed geometry.
Old 03-02-2009, 09:55 PM
szyd
how much did the banks ram cost ya?
and is that a bov on the one sid eof it??
Old 03-02-2009, 10:38 PM
detroitdiesel64 detroitdiesel64 is offline
if that is a blow off valve on the side where could i get one at?
