If I were to replace the factory turbo on the 04 6.0 what would be a good tow/street performance replacement with good throttle response and virtually no lag? I noticed shu873 put a 62/70 on what does that mean?
That means its a good turbo...
If I was you I would go with a non vgt from II or another company. More air, more cooling more hp longer lasting able to handle bigger injectors for even more power..... |
who is II?
II is Industrial Injection. I like the 62/70, it spools very close to the stock turbo with stock injectors IF you run a race file. It's fairly laggy on stock programming. I haven't had the opportunity to do any towing with mine yet, its only been on 4 days. I'm told I'll be able to easily. There are also a couple good aftermarket VGT's out there as well to choose from.
thanks! Like I said I'm new to the PSD thing.
