Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
  #21 (permalink)
Old 03-01-2009, 04:08 PM
Co. Neil Co. Neil is offline
what would it do
  #22 (permalink)
Old 03-01-2009, 04:09 PM
strokerguy strokerguy is offline
man i wish i was rich so i could try it
  #23 (permalink)
Old 03-02-2009, 06:45 AM
shu873 shu873 is offline
hillbilly keyboard racer
More air (turbo) and stock fuel still doesn't add up to much...
and if you want more fuel, you've got to build the entire fuel system to provide it, not just add injectors. Then you've got the problem of the heads lifting, going to need studs. Your EGR cooler is going to blow, got to delete that. Once you get it all running correctly your tranny is going to scream for mercy with all that power, time for a full build. The list goes on and just gets more expensive...
  #24 (permalink)
Old 03-02-2009, 09:21 AM
05 F350 6.oL 05 F350 6.oL is offline
shu873
what question are you answering??
  #25 (permalink)
Old 03-02-2009, 09:26 AM
HunterJ HunterJ is offline
I think it is probably out of your price range. Heres a break down for you
Injectors 2000
Fass 750
Headstuds 400
Twin turbos 6-7000
Intercooler 1000
NADP Race Trans 5-7k(?)
SCT 500
EGR Delete 600
Now there is some more little odds and ends but this a basic list.
  #26 (permalink)
Old 03-02-2009, 09:29 AM
Harohunter
thats a nice lookin truck how much did the bed cover cost ya?
  #27 (permalink)
Old 03-02-2009, 09:32 AM
It was on the truck when I bought it. They are about 900ish new.
  #28 (permalink)
Old 03-02-2009, 09:34 AM
wow im not to sure about that id rather get an sct or somethin is that what you have?
  #29 (permalink)
Old 03-02-2009, 09:35 AM
doubledrop doubledrop is offline
Injectors 2000
Fass 750
Headstuds 400
Twin turbos 6-7000
Intercooler 1000
SCT 500
EGR Delete 600
and those are just parts, not the labor to do it all
  #30 (permalink)
Old 03-02-2009, 10:39 AM
jbarker@bankspower jbarker@bankspower is offline
You may also want to consider having your heads ported to help make your new turbo (or turbos) more effective. Tons of boost pressure won't do much if the air can't get in the cylinder in the first place. Here's what the 6.0L flow numbers look like in stock form:
Intake port...
.000 Lift 0 CFM
.050 Lift 41.4 CFM
.100 Lift 80.4 CFM
.150 Lift 119.9 CFM
.200 Lift 145.4 CFM
.250 Lift 152.0 CFM
.300 Lift 154.8 CFM
.350 Lift 157.4 CFM
.400 Lift 159.3 CFM
.450 Lift 161.0 CFM
.500 Lift 161.9 CFM
.550 Lift 163.0 CFM
.600 Lift ----------
Exhaust Port....
.000 Lift 0 CFM
.050 Lift 37.0 CFM
.100 Lift 69.9 CFM
.150 Lift 93.2 CFM
.200 Lift 106.1 CFM
.250 Lift 111.2 CFM
.300 Lift 116.8 CFM
.350 Lift 119.2 CFM
.400 Lift 120.7 CFM
.450 Lift 121.3 CFM
.500 Lift 121.9 CFM
.550 Lift 122.3 CFM
.600 Lift 122.7 CFM
Tested at 28"
