need new turbo - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-25-2009, 09:44 PM Thread Starter
need new turbo
Do any of u guys no whats the best towing and street turbo on the market for the 6.0 ???
quadracer33 is offline
post #2 of 13 Old 02-26-2009, 03:25 AM
tex25025's Avatar
I really like my 64 mm turbo that I got from River City. I would imagine a 64-66mm would be alright for towing, any higher you'll run into some surging issues that may or may not be alleviated by tuning.
2006 6.0 King Ranch DRW
Spartan Stage 1 Towing Injectors
Headstuds
Beta Spartan Phalanx
Suncoast Heavy Duty Torqshift Rebuild
ITP Fuel Regulated Return
Straight Piped MBRP 5" Exhaust
64mm Non-VGT turbo
tex25025 is offline
post #3 of 13 Old 02-26-2009, 06:03 AM
back in the saddle
shu873's Avatar
Before I'd feel comfortable answering that question, I would like to know what you have already done to the truck for performance mods, and what are your goals for the truck? There are some pretty good turbo options in both the aftermarket VGT's and the non VGT's.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #4 of 13 Old 02-26-2009, 06:28 AM
tex25025's Avatar
Good point.
Street and towing I would imagine would be his goals since he was asking about a turbo for those applications.
Headstuds
64mm Non-VGT turbo
tex25025 is offline
post #5 of 13 Old 02-26-2009, 10:07 PM Thread Starter
I hav afe stage2 quadzilla adrinaline and grand rock dual stacks.
post #6 of 13 Old 02-27-2009, 01:12 AM
tex25025's Avatar
I hav afe stage2 quadzilla adrinaline.
That you'll have to get rid of. It won't be able to compensate for a turbo, particularly a bigger turbo that may be non-vgt, you'll have to be able to shut off the sensor for the vgt.
Headstuds
64mm Non-VGT turbo
tex25025 is offline
post #7 of 13 Old 02-27-2009, 08:04 AM
back in the saddle
shu873's Avatar
On my truck, I removed the sensor off my vgt, plugged it in and zip tied it out of the way. No codes and no troubles, just FYI.
To the OP, you really will need a custom tuned SCT to make the most of a turbo upgrade, but IMO you need to invest in other things before you need to worry about a turbo, but that's up to you. I think your stock VGT is more than up to the task for no more than you have done right now. Work on the supporting mods, such as fuel system, etc. before you worry about a turbo is my advise. That is unless of course your stock turbo is in need of replacement anyway.
Kurt
ARP's, EGR blocked
Banks technicooler
shu873 is offline
post #8 of 13 Old 02-27-2009, 09:17 AM
tex25025's Avatar
5 minutes on a computer program is all I needed. I would imagine it took you a little longer for that.
Headstuds
64mm Non-VGT turbo
tex25025 is offline
post #9 of 13 Old 02-27-2009, 10:45 AM Thread Starter
I had stuck vein's. So i ordered a stage1 hybrid turbo from industrail injection. my truck is an 03 f350 crew cab and this has been the first prob on it nock on wood . so is sct live wire the best tuner for the 6.0. i work grave yard shift pipefitting dont have a lot of time for the computer thanks for your help!!!!!
post #10 of 13 Old 02-28-2009, 04:26 AM
back in the saddle
shu873's Avatar
I'd personally buy a used Xcal2 or new Xcal3 with custom tunes and a set of analog gauges. The hand held's can run the same tunes as the livewire.
Kurt
ARP's, EGR blocked
Banks technicooler
shu873 is offline
