Anyone running a PPE lift pump? - Ford Powerstroke Diesel Forum
Old 02-16-2009, 07:57 PM
Im wanting to know if anyone is running the PPE lift pump for 6.0. If so would you recommend it or go with another lift pump?
Thanks
Old 02-18-2009, 08:15 AM
:::BUMP:::
Old 03-03-2009, 02:33 PM
double bump? I figured someone would run one. Adjustable 12-15psi, fairly inexpensive...
Old 03-03-2009, 02:37 PM
12-15 psi wont cut it.
Old 03-03-2009, 07:07 PM
Fuel pressure needs to be in the 51-55 range I believe.
Old 03-03-2009, 07:10 PM
I think the lift pump is for the Duramax. There website is messed up as for were what items go were.
Old 03-03-2009, 07:11 PM
good fuel pressure is about 60..i have mine set to 62ish..it holds about 58 wot
you need something with more pressure..fass..raptor pump..something like that
Old 03-03-2009, 07:27 PM
PPE Pumps are mainly used on Cummins and I think Duramax as well. However, it seems like the Cummins people like it the most. Guy I know that has an 02 12 valve was really raving about it.
Old 03-03-2009, 07:28 PM
About 60 is where you want it, but you don't want to go below 45psi if I remember correctly.
Old 03-03-2009, 07:34 PM
I believe 12 valves only existed until 1998, everything after that was 24 valve.
