EGR Cooler delete - Ford Powerstroke Diesel Forum
Old 02-16-2009, 08:50 AM
Send a message via AIM to FastFocus
EGR Cooler delete
Ok, so my truck is whistling and is going to get studs/new HG put in within the next week or so, i'm also looking at doing the EGR delete/bypass. i plan on doing the EGR my self(after i get it back from studs being put in) so i dont have to worry about any problems down the road any more. However i see there are a few ways to go about doing it. they are:
EGR delete - new intake manifold with EGR valve removed and welded shut
EGR cooler bypass - exhaust up pipe & EGR cooler delete tube.
EGR delete up pipe - just the exhaust up pipe from manifold to turbo removing connection from exhaust to EGR.
i'm not going to do the full delete because i'm not really wanting to pull the cab off myself unless i absolutely have to.
my question is this. how good is the EGR cooler bypass compared to the full delete? can it be installed without removing the cab? are there any problems vs the full EGR delete?
my last question is, i noticed that someone just did a write up on removing their EGR while doing studs, and they left the EGR cooler in place and just added an up pipe to disconnect the exhaust gasses from the EGR. what problems could i have if i just did the up pipe and left the factory coolant passages? what are the downsides and benefits to both? I love this truck, i wouldn't trade it for anything and i'm looking forward to having a bulletproof power stroke once the studs and egr are done. just need a little input.
thanks in advance!
Old 02-16-2009, 09:57 AM
Do not know the answers to most of your questions, but if you give Adam a call at First Coast Diesel hewill set you up. I have the full delete kit and it is well worth it.
Old 02-16-2009, 12:19 PM
You can bypass the EGR with a welded up-pipe, and you can have the EGR valve shut off with custom SCT tuning, or just literally unplug it, or pull it out and weld it shut (it may throw codes without the SCT though...) However even with all this you can still have an EGR cooler failure. As long as its there, it can (and probably will) fail. I plan on fully deleting mine when the weather gets nice.
You do not need to take the cab off for this project.
Complete EGR removal write up
Old 02-16-2009, 12:25 PM
so basically i SHOULD just go ahead and do the EGR cooler bypass and remove the cooler. Then everything that typically causes failures is gone. i already have tuning via ID so my EGR is off, just not removed yet. thanks for your help!
Old 02-16-2009, 03:21 PM
Yep, ditch that nonsense! Just make sure if you still have a warranty that the dealer is cool with it. Otherwise you may find yourself footing for some bills later on...
I'm at the point where I just want it gone no matter what.
Old 02-16-2009, 04:18 PM
i'm at that point too, i want a dependable engine no matter what i throw at it. and with studs and the EGR gone it should be just that.
Old 02-16-2009, 04:45 PM
is this mod only for the 6.0?
Old 02-16-2009, 05:14 PM
Yep, 7.3's didn't have this emissions bull****!
Old 02-16-2009, 06:28 PM
Is it absolutely necessary to take the cab off when you do the EGR delete?
Old 02-16-2009, 06:30 PM
Next time try reading the posts...
