Help!! EGR Block Off - Ford Powerstroke Diesel Forum
Old 02-11-2009, 08:42 PM
Ok, I'm Looking for a plate to block off my EGR Up Pipe.. I don't wanna delete the whole system. I just cost too much & takes too long & from what I understand If the Exhaust cant get in there the coolant won't boil. And if the EGR is shut off by the SCT then coolant cant get into the heads unless my cooler is alread bad & leaking which it isn't... I Need Some Prices & Places To Get This Piece.. Or If Anyone Could Tell Me How To Fab This Part That Is A Possibility As Well!! THANKS!!!
Old 02-11-2009, 09:16 PM
I would think you could just fab up a freeze plug and weld it in the up pipe????
Old 02-11-2009, 09:22 PM
There is a really good write up on here .Iam going to try to add it in .Iam not sure how to do it maybe some else can help.
EGR Up Pipe Delete Homemade
Old 02-12-2009, 05:38 PM
Thanks Guys!!! Got My Freeze Plug Tonight!!! Me & The Welder Have Got A Date This Weekend!!!!!
Old 02-12-2009, 07:10 PM
You should try to do a write up on it.
Old 02-12-2009, 07:28 PM
I will try. I'll take as many photo's & put step by step instruction on what I did on here ASAP.
Old 02-12-2009, 07:50 PM
Mr Hoosier, If you have the time and energy to remove the up pipe. Then remove the up pipe weld a freeze plug in the Y to the cooler and bolt it back up.
If you do not want to remove the up pipe. You can buy a block off plate ($35.00) and slip it in between the up pipe y to the cooler and the cooler itself.
Good luck.
I see you are up north. If you plan to remove the up pipe. Spray the bolts a day before. It will make life a bit easier.
Old 02-12-2009, 07:53 PM
10/4 I'm taking it off & welding it shut!! I've got a whole can of PB Blaster with my Up Pipe's name on it!! It will be soaking All Day tomorrow!!
Old 02-12-2009, 08:01 PM
Let me know how long it takes you.
Buy the way, I got a Tech file sent to me last month stating the 2.5's need to run 91 octane. You need to look into that 225 your running.
Crap, Sorry man. I am a Triton dealer and do about 300 Yamaha's a year. Big fan of the MPI TS'S. Iv'e had about 3. Although I have been running an Opti this year on our demo. I seem to get a bit more top end out of it.
But a true lover of the HPDI.
Old 02-12-2009, 08:04 PM
Also spend a week a year in Southbend (Godfrey Marine) Goshen (Keystone) and Elkhart.
Good country up there
Good luck with the block off If you run into any problems post them up.
