Injector opinions - Ford Powerstroke Diesel Forum
 10Likes
post #1 of 22 Old 08-19-2014, 04:55 PM Thread Starter
hdfattboy2001's Avatar
Injector opinions
Gearing up to do a Stud Job with delete and regulated fuel system while I have the cab off because my HG's are taking a crap.
Truck only has 80k miles on it, But my gut is telling me to do my injectors while Im in there because its going to be way easier now than later.
I dont want to get crazy with injectors because I dont want to have to go with a new turbo. BUT if im spending the $ I would like to gain some good tow power and more grunt for the street instead of just going with stock injectors. Looking for any recommendations on who to buy injectors through and what i should go with for tow/street use. Truck right now is SCT tuned By Gearhead and Piped.
Thanks
Brad
hdfattboy2001 is offline
post #2 of 22 Old 08-19-2014, 04:56 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
155/30s and renegade diesel
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 22 Old 08-19-2014, 05:05 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Stick with some good well known builders.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 22 Old 08-19-2014, 05:11 PM
renegade has good injectors- mine perform flawlessly but I would go another route unless you want to wait a good while for injectors. He is busy as can be
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 22 Old 08-19-2014, 05:26 PM
MWilbur516's Avatar
My vote goes to Rykan at Holders Diesel. You send him injectors, he mods and you get your 80k mile injectors back, not someone else's 210k injectors. He does outstanding work and flows his injectors to insure they are right before they go out.
I'd do 175/stock injectors from Rykan. You will not be sorry.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #6 of 22 Old 08-19-2014, 05:31 PM Thread Starter
One thing is I have time to wait before I pull the cab (prob October-November) but once truck is down I need it back in operation within a week.
post #7 of 22 Old 08-19-2014, 06:24 PM
strokin6L's Avatar
Quoted: 4 Post(s)
I just had MPD build me one injector cause I had a bad one. Craig got the bad one monday, build the new one the same day and shipped it back to me today. PersonalIy would go with MPD, RCD, Full Force or Holders.
post #8 of 22 Old 08-20-2014, 11:01 AM
I got mine from holders, haven't got to put any miles on them yet but the service was awesome.
Yeeyee87 is offline
post #9 of 22 Old 08-20-2014, 11:15 AM
snafu!'s Avatar
This is the list of builders you should highly consider, all of them make great injectors. Also consider replacing the spool valves while you have them out.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #10 of 22 Old 08-20-2014, 12:14 PM
scparrish's Avatar
Quoted: 100 Post(s)
Feedback Score: 3 reviews
^^^That is the list of injector builders I would consider, I wouldn't venture outside that list personally.
Also go with either 155/stock or 175/stock. If you ever plan to do a turbo I would lean more toward the 175s if you plan to keep the factory turbo forever just stick with the 155s.
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
