Mishimoto Releases 6.0L Powerstroke Low/High Temperature Thermostats! - Ford Powerstroke Diesel Forum
 18Likes
post #1 of 50 Old 08-19-2014, 09:07 AM Thread Starter
Supporting Vendor
Quoted: 35 Post(s)
Hey guys,
Check out our newly released low and high temperature thermostats for the Ford 6.0L Powerstroke!
Ford 6.0L Powerstroke Low-Temperature Thermostat, 2003-2007
Product Specs
  • Direct fit for the 20032007 Ford 6.0L Powerstroke
  • Lower activation temperature allows coolant to flow through the engine earlier, maintaining lower temperatures (Mishimoto thermostat activates at 185F vs. factory 192F)
  • Ideal for vehicles in warm climates or under extreme towing/driving conditions
  • Mishimoto Lifetime Warranty
Tech Specs
Ford 6.0L Powerstroke High-Temperature Thermostat, 2003-2007
Product Specs
  • Higher activation temperature restricts coolant flow for a longer time, resulting in quicker engine warm-up (Mishimoto thermostat activates at 200F vs. factory 192F)
  • Ideal for use in cold climates
Tech Specs
Images
Feel free to follow up with any questions regarding these new thermostats!
Mishimoto is offline
The Following User Says Thank You to Mishimoto For This Useful Post:
NicD (05-24-2016)
post #2 of 50 Old 08-19-2014, 09:11 PM
bgraiders323 is offline
post #3 of 50 Old 08-20-2014, 05:24 AM
SargentoPistola's Avatar
In the event of failure do they fail in the open position? It's awesome companies are still developing and innovating for these old beasts.
kinnisoj, john galt and Stiles like this.
-Kyle-
2004 6.0 Eddie Bauer Excursion. The Man Van.
SCT w/ MPD
Edge CTS w/ EGT Probe
Banks exhaust
EGR Delete
Coolant Filter
Riffraff Boots
Stuff
1999 F-150 XLT 4.6 4x2. The Backup.
SargentoPistola is offline
post #4 of 50 Old 08-20-2014, 05:32 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
hmmmmmm looks like a must do Batman.......
john galt likes this.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 50 Old 08-25-2014, 03:15 PM
Mexfdmnb's Avatar
The 200* is what I am considering my ect never gets past 190 and is steady at 182-186 I changed t stat with OEM one back in Feb I live in upstate NY if I get the 200* t stat will that be too high for the climate I live in?
[SIGPIC]2005 F-250 CCLB zf6
leveling springs, 4" turbo back 5" tip
oil filter bypass, coolant filter
deleted, studded, sinister fuel filter cap,
SCT X3, S&B CAI, blue spring,
truxedo lowpro qt bed cover,
black diamond hg,
stand pipe, dummy plugs, stc fitting, Airdog 150,
Beans Diesel sump, edge insight cts, eadge eas pyro, turbo feed line,
Turbo drain tube, mishimoto 200* t stat, WW2
CCV MOD, High idle mod, PMF traction bars, 08 diff cover, 20" led light bar
Mexfdmnb is offline
post #6 of 50 Old 08-26-2014, 04:19 AM
PowerStrokedRedneck's Avatar
My biggest argument with changing the t-stat temps is that you changing how it was designed to operate. No if you live in the south or do a lot of towing in warmer climates it would be worth it using a colder unit. On the same note, if you live way up north were its cold most of the time, a hotter one would be nice. But for the rest of us, it just seams like an unnessicary thing to do.
However I do agree that it's nice to see companies still doing R&D for our engines.
PowerStrokedRedneck is offline
post #7 of 50 Old 08-26-2014, 04:27 AM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
I might just have to be the guy to try out the 200 stat this winter I hear were supposed to get hammered like last year in upstate NY
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #8 of 50 Old 08-26-2014, 05:03 AM
bootcamp's Avatar
Quoted: 3 Post(s)
We know what the pros are but what are the cons to this, I live in Louisiana, the summers are HOT and the winters are cold, just no snow. I dont want something I have to swap out every year
USMC
05 F250 6" LIFT, Custom Fuel System, RR KIT, Fuel, TRANS, OIL, PYROMETER GAUGES, Fluid Damper, TSD & IDP Tunes, HellmaNs Sump, 4.10 Gears, ARP +625,Factory Gaskets,Apex ported manifold, MBRP EXHAUST , Atlas 40, Warren 175/75 injectors, 68mm Pmax w/ Batmowheel, BPD rad, BPD water pump, Sinister Y Pipe,Alradco Intercooler, O-Ring Heads and the list goes on.
bootcamp is offline
post #9 of 50 Old 08-26-2014, 05:19 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
That will make someone in Canada spit cofffee all over there ccomputer for sure!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 50 Old 08-26-2014, 05:26 AM
shughey00's Avatar
Quoted: 35 Post(s)
I live in Maine and was drinking my coffee when I read that...still trying to clean the coffee out of my keyboard...:-o.
Trying to start a diesel on a -15 to -20 degree is a cold day.
Having fun obviously.
" border="0" />Professing themselves to be wise, they became fools
2006 F350 4x4 FX4 CCDRW, 4.30 gears, Edge CTS, Edge EAS EGT, 19.5 Rims, Blue Spring, Riff Raff hot side boots, Zerex CAt-1, IPR coolant filter, Ecm rollback and FICM Atlas 40 PHP, DC 185 alternator, Rancho RS7000MT, Ranch 9000 on the rear, 08 tranny pan and filter, heavy duty IPR EGR cooler...that now has been plugged off.
shughey00 is offline
