4.10 or 4.30 with 315/70x18 - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 22 Old 08-16-2014, 11:26 AM Thread Starter
Pro fuzz's Avatar
Quoted: 29 Post(s)
Anbody regeared for pulling 15000 lbs ??
2006 F350 KR cclb 155/stock full force powermax / WWII leveled carli 2.5 pintops 08&up full rear spring ouo 3link arms 36 toyo mt 4.30 yukon grizzly rear locker :yike
s:
New ride 2015 tow boss dpf & egr lost !!
Pro fuzz is online now
post #2 of 22 Old 08-16-2014, 11:37 AM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Feedback Score: 4 reviews
How frequently do you tow? At 35" tires, you would be fine with either gears. It might not be worth it to your pocketbook to just go up to 4.10's if you are looking for better mileage. The 4.30's will give you better power while towing and are the choice for the Tow Boss (dually) setup for that reason.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
The Following User Says Thank You to Evil Eye For This Useful Post:
Pro fuzz (08-16-2014)
post #3 of 22 Old 08-16-2014, 02:33 PM
It has been a while but I was looking at doing that with my ol 04 I had for a while. From what I got talking to a local gear shop the 4.30s were about the same as 4.10s with stock tires and the 4.10s were roughly the same as 3.73s with stock tires. This is if your using 35" tires.
This is just how the tranny and stuff see it so transmission of power will be about that however gas mileage is another story.
2003 F350 Lariat 6.0L
MTW stage 1, 4" MBRP, IPR coolant filter, 05 front cover and water pump, everything else pretty much stock.
Quint is offline
The Following User Says Thank You to Quint For This Useful Post:
post #4 of 22 Old 08-16-2014, 06:26 PM
bondajb's Avatar
With a true 35" I recommend the 4:30's if a larger charger is in the future definitely 4:30.. I like my 4:10 but they make 60-65 difficult towing.. I am right between gears at that point.. the truck pulling 15 - 17k loves 70-80 mph. However tuning is huge.. I am. Amazed in the difference between tuners. That is key for sure
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #5 of 22 Old 08-16-2014, 07:39 PM
peixinho's Avatar
Quoted: 231 Post(s)
Another guy had a similar question... So i just copied and pasted my input. Hope it helps
It is fairly simple math... but it will all come down to what you want. Most guys like to tow around 2500-3000 rpms to maintain a nice speed with a heavy load. 2000 rpms will be lugging and you won't be able to maintain speed up hill and 4000rpms is way to high to maintain for long periods of time because it will wear out your motor and run much hotter...
So.. decide at which speed and rpm you want be able to pull at. A lot of guys like 65-70mph at around 2500rpms... so...
35" tires
3.73 gear ratio
2500rpms
5th gear = 63mph
6th gear = 98mph
That makes you going either just slightly too slow or way too fast. If you try and hold OD/6th gear at 70mph then your rpms will be around 1800rpms and you will not be able to keep up that speed up the hills (even with a ton of mods)
So lets change the gear ratio to 4.10
35" tires
4.10 gear ratio
2500rpms
5th gear = 60mph
6th gear = 89mph
So lets change the gear ratio to 4.30
35" tires
4.30 gear ratio
2500rpms
5th gear = 55mph
6th gear = 85mph
So with 4.10 gears if you went up hill at a safe 65mph in 5th gear, but cruise on flat ground at 75mph in 6th gear... then this is what you would get
35" tires
4.10 gears
65mph in 5th gear = 2800rpms
75mph in 6th gear = 2100rpms
So with 4.30 gears if you went up hill at a safe 65mph in 5th gear, but cruise on flat ground at 75mph in 6th gear... then this is what you would get
35" tires
4.30 gears
65mph in 5th gear = 2900rpms
75mph in 6th gear = 2200rpms
You get the idea... here are some links to help. Just play with it until you get the numbers that are most desirable to you
5R110 - Power Stroke Wiki
Gear Ratio Speed Calculator
bgraiders323 likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
The Following 2 Users Say Thank You to peixinho For This Useful Post:
bgraiders323 (08-16-2014), bootcamp (08-17-2014)
post #6 of 22 Old 08-16-2014, 08:13 PM Thread Starter
Pro fuzz's Avatar
Quoted: 29 Post(s)
I'm running 155/stock inj with a powermax WWII atlas 40 with heavy tow tune from bill @ php truck falls under turbo at 65 down shift all kinds of power even if I get it to unlock converter EGT goes down to around 1100 ish
s:
post #7 of 22 Old 08-16-2014, 08:16 PM Thread Starter
Pro fuzz's Avatar
Quoted: 29 Post(s)
I think I'll do 4.30 regear with Detroit locker in the rear with a tru trac in the front
Evil Eye likes this.
s:
post #8 of 22 Old 08-16-2014, 08:17 PM Thread Starter
Pro fuzz's Avatar
Quoted: 29 Post(s)
Thanks for the input guys
s:
post #9 of 22 Old 08-17-2014, 04:49 AM
Slacker
Evil Eye's Avatar
Quoted: 223 Post(s)
Sounds like a plan. I'm very interested to see how this setup does since I've been researching this setup for quite some time but just haven't gotten around to doing it.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #10 of 22 Old 08-17-2014, 12:51 PM
bootcamp's Avatar
Quoted: 7 Post(s)
I regeared my truck with the 4.10's and kicked myself in the but for not going with the 4.30's. so now I am considering to bite the bullet again and regear it to 4.30's.
USMC
05 F250 6" LIFT, Custom Fuel System, RR KIT, Fuel, TRANS, OIL, PYROMETER GAUGES, Fluid Damper, TSD & IDP Tunes, HellmaNs Sump, 4.10 Gears, ARP +625,Factory Gaskets,Apex ported manifold, MBRP EXHAUST , Atlas 40, Warren 175/75 injectors, 68mm Pmax w/ Batmowheel, BPD rad, BPD water pump, Sinister Y Pipe,Alradco Intercooler, O-Ring Heads and the list goes on.
bootcamp is offline
