cold air intakes - Ford Powerstroke Diesel Forum
 25Likes
post #1 of 89 Old 08-15-2014, 06:31 PM Thread Starter
cold air intakes
Which aftermarket cold air intake for the 6.0 turbo diesel has anybody had work the best for them?
rebelroughneck is offline
post #2 of 89 Old 08-15-2014, 06:35 PM
F3502wd's Avatar
Feedback Score: 3 reviews
S&b seems to be the answer
04 F350 l 6" Pro Comp Lift l American Force 22.5 l PMF Stage 2 traction bars with blocks l Fabtech dual SS l KD Fabworks l 05 conversion l 1Aauto l S&B l MBRP 5" turbo back l WPE up pipes l WPE RR l Holders Diesel 190/75 l KC Turbos stage 2
F3502wd is offline
post #3 of 89 Old 08-15-2014, 06:46 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I would argue that with the zoodad mod we already have a cai.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 89 Old 08-15-2014, 06:58 PM
F3502wd's Avatar
The never ending debate
ODAWG714 and bgraiders323 like this.
F3502wd is offline
post #5 of 89 Old 08-15-2014, 06:59 PM
Heavy_GD's Avatar
Quoted: 1432 Post(s)
You would argue that?
ODAWG714 likes this.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #6 of 89 Old 08-15-2014, 07:28 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
If I was bored enough
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 89 Old 08-16-2014, 12:29 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Top 3 is gonna be
NoLimit
AFE
S&B.
I've heard excellent results with the NoLimit from a certified very picky diesel tech
sho669 and bgraiders323 like this.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
The Following User Says Thank You to ODAWG714 For This Useful Post:
Dave (08-17-2014)
post #8 of 89 Old 08-16-2014, 07:11 AM
F3502wd's Avatar
Wait, what are you arguing That zoodad thing is a waste, but then again its free
F3502wd is offline
post #9 of 89 Old 08-16-2014, 02:28 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I dont think its a waste....does it do ALOT....well no. But what makes a cold air intake a COLD air intake? It has to find air from outside of the engine bay. We can all agree that the stock intake set up is actully pretty dang good up to around 500 hp. And thats a number that I would say 90% of us are not at. So with the zoodad mod we have opened up the supply of fresh cool air from OUTSIDE of the engine bay and RAM it right into the air filter. Making it a fairly decent cold air intake. I dont care what kind of pretty air filter with a chrome pipe you got if your sucking up pre heated air from under the hood YOU AINT GOT NO COLD AIR INTAKE!
See I told you I could argue that.....you may not agree and thats ok. Sometimes the truth hurts...
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 89 Old 08-16-2014, 03:31 PM
Ive still gotta do the zoodad portion of the mod. Gonna try to do it this weekend. A while back I did cut the front tube portion off of the stock intake. Basically opened up the entire front of the filter with the exception of about 1.5" ring around the edge that holds the filter in tight and allows the clips to still clamp onto it. So far is working pretty good.
I may do some more modding with making more of a channel for the fresh air to get to the front of the filter but without limiting it to a tube. Not that I probably really need it anyways but its fun playing with stuff that doesnt cost ya much.
2003 F350 Lariat 6.0L
MTW stage 1, 4" MBRP, IPR coolant filter, 05 front cover and water pump, everything else pretty much stock.
Quint is offline
