hybrid injector sizing for non street use truck? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-12-2014, 09:26 PM Thread Starter
Ok I'm building a motor and going to be feeding it with a very large s400 turbo, can someone please explain hybrid injectors and nozzle sizing to me, from reading the nozzle size determines how fast the injector can dump the cc volume of fuel per injector cycle, is the way I'm interpreting this correct? And if so how do you figure out the right way to determine what size is needed for said application without just saying O it worked on so and so's truck so it will work for me, and also what is a accurate way to measure icp voltage, with a custom tune fooling the ecm
Jeremy
2004 Black&Gray F250 Harley Davidson Crew Cab 4X4
MODS:
6" all spring lift & dual front shocks with 35 NITTO's, MBRP SS cool duals, Harley Orange Ford emblem, ARP studs & OEM gaskets, Adrenaline HPOP, All Ford updates, Owner built fuel system and RR, Owner build trac bars, Warren Diesel 190/75s, MTW hybrid, SCT liverwire ts with IDP tunes & IDP FICM programmer, Sinister Diesel coolant & bypass filter kit, Elite Diesel coolant crossover kit, 07 Harley lights & 6k HID's, Electric Fans
JBowen747 is offline
post #2 of 4 Old 08-13-2014, 07:29 PM
I'm no expert (really a noob) but the nozzle size is % over stock. So a 175cc is 30% larger than 135cc injector; which means you need a 30% bigger nozzle to evacuate the same amout of diesel in the same size pulse.
So if you subtract what 135 by what size you want to go to, and then divide that by 135 you'll get what % you need to go to.
For example- 175-135= 40. 40/135= .29629 or 30%.
Yote is offline
post #3 of 4 Old 08-14-2014, 09:24 AM
I've got a little experience with hybrids non vgt and tuning for them. What size turbo are you looking at running?
Icp voltage is the best way to measure the pressure.
Also correct that the larger nozzle speeds the process of emptying the barrel of the injector. 100 percent nozzle is pretty common especially when your not worried about street use.
2006 f250
on 37s
few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #4 of 4 Old 08-14-2014, 12:03 PM
william_ace's Avatar
Quoted: 2 Post(s)
You need to post over on the army for that one. You'll get a load more responses there as they are the more hardcore builders. IMO anyway. What are the goals for this truck? Drag? Sled pulls? Street? What are your power goals?
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
