muffler cut off gains - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 23 Old 08-12-2014, 05:31 AM Thread Starter
My 03 6.0l is 100% stock. Although I have a things in mind with the truck but a fast truck isn't it. I want it to sound good and tow my car around when needed. My brothers buddy has an 04 and he recommended me cutting off the exhuast just before the bed. Apparently it sounds great but I'm curious if there's any gains from this and would it be stupid loud in the truck. My mexico race car had open open headers and there was massive drone. Don't want that out of a DD rig..
powerjake is offline
post #2 of 23 Old 08-12-2014, 05:42 AM
dannanw's Avatar
Quoted: 67 Post(s)
Garage
get a aftermarket extaust...it'll be way to loud in the cab for a dd but thats my .
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 23 Old 08-12-2014, 05:46 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Id suggest you run something like the Diamond Eye 5" straight turbo back set up. Price was very reasonable. The set up seems to be very well built and I agree,f you cut it off just behind the cab the cab drone is gonna be BRUTAL!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 23 Old 08-12-2014, 06:06 AM
madpowerstroke's Avatar
I have a 4" diamond eye exhaust with muffler in my average Joe truck and it does well on Dyno. I also have a truck with 4" straight pipe and it is too loud for me. Both are full exhaust, and exit in stock location, the straight piped one has that has high rap noise when at WOT, that's what I don't like. The truck with the mufflers sounds little more quite at cruise and less high rap noise at WOT. The muffler is a straight through design so doesn't restrict a thing. I just picked up two mufflers that have a little bit of scoups to see how I like the sound. The cat is the biggest blocker, other then that there isn't any gain from going without a muffler.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #5 of 23 Old 08-12-2014, 06:09 AM
johnnybgood's Avatar
Quoted: 82 Post(s)
I'd say no gains, especially if you're talking about any power gains. Nothing you would probably notice.
There was a difference going from full stock exhaust to a turbo back exhaust though. Slightly quicker feeling spool, and it jumps up quicker on my gauge to.
2005 Excursion Limited w/259K+ miles
-Turbo back exhaust -Harley Headlights & Grill
-OEM 20's -FICM Tuner -Torque Pro App
johnnybgood is offline
post #6 of 23 Old 08-12-2014, 03:25 PM
Just remember for the 03 and with a straight pipe its going to be alot louder then what it is now. Primarily the turboo whistle.
Pretty sure alot of the restriction in the stock setup is in the cat anyways. You could clean that out and leave everything the way it is if you dont want to get a new exhaust. 4" should be plenty if your not going crazy with anything else.
2003 F350 Lariat 6.0L
MTW stage 1, 4" MBRP, IPR coolant filter, 05 front cover and water pump, everything else pretty much stock.
Quint is offline
post #7 of 23 Old 08-13-2014, 08:26 AM Thread Starter
I took the muffler off and didn't notice any drone. At idle the engine is louder than the exhuast lol. I haven't really looked at the cat yet but if I take that off will it throw a code? I have noticed you can hear the turbo alot better and under wot it sounds like it loads up like it's dumping massive fuel. But cruising it kinda sounds like a jet. Now wouldn't the cat convertor net some money to put towards a SS 4in straight pipe? Cars go for like 75$ and I figured these should Net a hell lot more.. so only gains I'll see is the hill billy weight reduction
post #8 of 23 Old 08-13-2014, 08:37 AM
If you take the Cat off there will be no code thrown for it in a 03. I had to put my cat back in after I cut it to a 4inch in and out. With it out you could hear it a 1/4 mile away with the 03 turbo.
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #9 of 23 Old 08-13-2014, 08:43 AM
jmeaby's Avatar
Quoted: 16 Post(s)
I actually noticed a slightly increase in spool up time when I did my exhaust. However I think once you get up mo ing some air it feels stronger up top. You will get a drop in egts but bottom end you lose a little too you gain a little
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #10 of 23 Old 08-13-2014, 09:09 AM
Quoted: 82 Post(s)
Ya I've heard that one to with the 4'' downpipe. The kit on mine is 3.5'' dp and 4'' cat back with the delete and just added 5'' from axle back.
