New Turbo? - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 12 Old 08-11-2014, 04:47 PM Thread Starter
RoCkfiSh363's Avatar
New Turbo?
Hey guys I think it may be time for a new turbo. My boost is really low while cruising and my EGTs climb up to about 900 at 60 mph. I thought that swapping in the 4.56 gears would help put some load on the turbo but it still never sees more than 18 psi wide open. I was looking at the Powermax stage 1. I don't tow too much very often these days just over the Oregon mountains once in a while with a small ski boat. Would It be worth it to get the $1300 powermax or just a stock replacement. Going to put new Dieselsite boots on it while I'm at it. Any input is appreciated.
05 EX Cab Short
8 inch Fabtech
38 inch SSRs on 17x10 Centerlines(powdercoated)
SCT Innovative tunes
Banks CAI
Offroad MBRP Stainless 4.5 " and up pipe.
Auto Meter EGT, Fuel pressure, Trans Temp, Oil temp, water temp gauges.
Blue spring , bored 3 hole banjos.
ARP Studs
OEM Ford gaskets.
EGR Delete, cooler delete.
Bulletproof stand pipes
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
Innovative 48v FICM Performance flash.
RoCkfiSh363 is offline
post #2 of 12 Old 08-11-2014, 05:27 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I've driven in the mountains on the 5 through Oregon with a powermax. With proper tuning it will be just fine. And if you have larger tires I'd suggest regearing. I'll pm ya a price on a turbo.
While your in there it may be a great idea to upgrade your up pipes to heavy duty bellows. I'll pm you a price on those as well
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 12 Old 08-11-2014, 05:44 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
My bad I just saw you slapped in 4.56s. The gears should have helped a lot. Is your truck making any type of strange whistle sound? Any smoke at idle?
Oliver
ODAWG714 is offline
post #4 of 12 Old 08-11-2014, 05:46 PM Thread Starter
Thank you! Almost sounds like I'd be better with a stage 1 rather than a 1.5? Not really going to be racing it too often. Long drives over steep grades mainly. I'd like to keep EGTs as low as possible and drivability smooth. What are your thoughts?
05 EX Cab Short
8 inch Fabtech
Banks CAI
ARP Studs
OEM Ford gaskets.
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
post #5 of 12 Old 08-11-2014, 05:52 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
Stage 1 all the way for them grades you guys have.ill pm you my number
Oliver
ODAWG714 is offline
post #6 of 12 Old 08-11-2014, 05:59 PM
Heavy_GD's Avatar
Quoted: 1500 Post(s)
Feedback Score: 3 reviews
If 900 is the max and it's low while cruising then I don't see the issue
GD
Heavy_GD is offline
post #7 of 12 Old 08-11-2014, 06:02 PM Thread Starter
No... No, it's 900 cruising at 60 on a flat to slight up hill. 1050 if I'm not paying attention.
05 EX Cab Short
8 inch Fabtech
Banks CAI
ARP Studs
OEM Ford gaskets.
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
post #8 of 12 Old 08-11-2014, 06:04 PM Thread Starter
Truck definitely feels better with the gear change as far as rpms and shifting like a stock truck but I don't think it really helped much with the boost or EGT. It always has made kind of a funny whistle, no smoke at idle. Thinkin boost leak?
ODAWG714 likes this.
05 EX Cab Short
8 inch Fabtech
Banks CAI
ARP Studs
OEM Ford gaskets.
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
post #9 of 12 Old 08-11-2014, 06:06 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
You may have a boost leak. Check your cac boots especially the one on the turbo compressor outlet.
Also check your bellows on your up pipes
Oliver
ODAWG714 is offline
The Following User Says Thank You to ODAWG714 For This Useful Post:
RoCkfiSh363 (08-11-2014)
post #10 of 12 Old 08-11-2014, 06:17 PM
madpowerstroke's Avatar
I would say you have a boost leak, before going to a new turbo you need to find out what the issue is. I have seen too many people swap turbos for a problem only to get mad when the new turbo still does same. If you have monitor which you should look at VGT duty cycles to make sure it is doing it's job, but I would have to say you have a boost leak on the exhaust side, probably the bellows on y-pipe, on even exhaust manifolds loose. Easy to check just find a trusted friend and have them brake torque the truck, if smoke comes from under hood there you go. By the way don't go crazy on the brake torque, just hold brake in gear and give it a steady small amount of pedal. Better to do quick checks to rule things out.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
The Following 2 Users Say Thank You to madpowerstroke For This Useful Post:
MT KingRanch (08-20-2014), RoCkfiSh363 (08-12-2014)
