Securing 4 Gauge A-Pillar Mount - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-11-2014, 02:30 PM Thread Starter
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
I am getting a new console built for my rig and moved my gauges to the A-Pillar this weekend. I'm a bit concerned with the mounting as the pillar in my Dodge was a full replacement where this one is a facia or sorts that uses plastic rivets to secure itself to the existing pillar.
After lots of fighting, drilling and cutting, i managed to secure the pillars and wire the Fuel Pressure, Coolant Pressure and Pyrometer gauges and my CTS on the bottom. It did help that i have my rigid 50" wiring running up that A-Pillar as well. Problem is, now the pillar is considerably heavier and, well, I beat the hell out of this pig offroad and all that's connecting it to the pillar is the 3 clips. Has anyone ever run a nut-sert/bolt to secure the cover to the actual a-pillar for more secure mounting?
OCVeloMan is offline
post #2 of 12 Old 08-11-2014, 04:16 PM
Deathrod's Avatar
Quoted: 3 Post(s)
ive had mine installed since 06 with just the plastic rivets or whatever they are and havent had any issues. Granted mine is only a 3 gauge but I thought the same thing when I installed it.....feels flimsy if you shake it by hand......years later hasnt moved.
2006 6.0, innovative tunes, intake/exhaust, misplaced smog parts...blah blah blah. 1930 model A stuffed w/12v cummins, he351ve over Ht3b
Deathrod is offline
post #3 of 12 Old 08-11-2014, 05:39 PM
jetjock15's Avatar
Quoted: 113 Post(s)
Mine has held with the rivets and I beat her pretty good. Just broke another wheel this weekend. The plastic rivets seem to work.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #4 of 12 Old 08-11-2014, 05:41 PM
jetjock15's Avatar
Quoted: 113 Post(s)
Hey on a side note, where you located(Carli)? I'm at champion wheel tomorrow at noon picking up new beadlocks for my off road car, they in lake Elsinore, if your close maybe I could stop in.
post #5 of 12 Old 08-11-2014, 05:48 PM
john galt's Avatar
Quoted: 1501 Post(s)
I would get a new pilar moiunt that felt secure or drive some self tappers into the frame to secure it
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #6 of 12 Old 08-12-2014, 07:04 AM Thread Starter
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
We're 20 minutes north of Elsinore in Corona! Drop in for sure!
422 Jenks Circle
Corona, CA 92880
post #7 of 12 Old 08-12-2014, 07:05 AM Thread Starter
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
Well then, as long as I'm not alone I will beat on the truck and see if it falls. If it does, I'll bolt it up but i guess i'll leave it for now. Already been airborne a few times and it's not moving.
post #8 of 12 Old 08-12-2014, 08:49 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Champion says my wheels are not ready and they going to ship to Vegas tomorrow (their dime cause they said they'd be ready today). With this in mind, I'm going to cut north of LA on way to Vegas (I was up in OR), ill catch you next time I'm close.
post #9 of 12 Old 08-12-2014, 07:48 PM
smoke=cool=little kid
The plastic rivets are good to go, if the don't hold up, pull it off and use self drilling pan head screws, fill the head with epoxy or bon do, paint the screw head. Will hold perfectly with whatever you throw.at it.
Also jetjock, I live in lake Elsinore now. Lol. Wish I would've saw this earlier
2004 F250 CCSB 4×4
Typical mods and performance parts
SCjake is offline
post #10 of 12 Old 08-12-2014, 10:18 PM
Deathrod's Avatar
Quoted: 3 Post(s)
I love the radioactive green lake elsinore water!!!!
Deathrod is offline
