New Fuel System Questions - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By dieseldan73
post #1 of 10 Old 08-10-2014, 01:36 PM Thread Starter
dieseldan73's Avatar
Hello, finally got my new fuel system complete. Got a Beans sump, -10 to water seperator, Fuelab 41402, 2 micron filter, -8 up to y-block, then -6 to each head and -6 to Fuelab regulator and back to the tank. First question is how much is horsepower affected by low pressure? I always thoughty truck ran great and had a lot of power even though I was dropping into the lower 20's at WOT. It now holding 55psi at WOT and doesn't drop more then 1 psi, but the truck feels like it has a lot more power. I thought I was imaging it, but I took my friend with me who knows my truck really well and he agrees it has a lot more ballz. He says it feels like I changed injectors. Could that low fuel pressure been costing me that much horsepower?
Next questions is about my pre head and post head pressures. Before the pressure at my fuel bowl and regulator were always within 1 psi. Now I have pre head at my y-block and post head at the regulator and the pre head one reads 8 psi higher? They are same sending units I had before and I even swapped them thinking one could be messed up, but they're not. but could it be that the Fuelab pumps so much fuel that the lines coming from the y-block to the heads and the 90 degree fittings are restrictive? Has anyone else have both pre head and post head fuel pressure readings with aftermarket pumps? I set the regulator to the regulator sensor since I want my injectors to have 55 psi, but now my pre head one has about 62-63 psi. Just wondering if this is normal or not.
2005 Ford f350 CCSB King Ranch
MTW MadMax Turbo
Warren 155/30 injectors
EGR Delete
BPD Oil Cooler, FICM, Oil Bypass, Water pump
Flo-Pro 5" Exhaust, Cat Free, Muffler Free
All updated FORD Parts
ARP Studs With Factory Gaskets
PI Stallion Converter
TSD SPD. Thanks Chris,
Edge CTS monitoring
35x12.5x20 Dick Cepek FC-2 on Chrome Rockstars
4" Zone lift with Bilstien 5100's
dieseldan73 is offline
post #2 of 10 Old 08-11-2014, 04:10 AM
madpowerstroke's Avatar
That is interesting, I only measure at the regulator, I don't know that of anyone monitoring both. I could take a guess at it, but wouldn't be accurate. Maybe someone else can explain why, and I will ask around to see if I can find a answer for you.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #3 of 10 Old 08-11-2014, 04:17 AM Thread Starter
I started monitoring both when I began having problems last year. It was always within 1 psi of each other, the pre-head always being higher. Now pre-head is 8-9 psi higher. I'm thinking it has to do with the pressure of the new pump. I figured someone has to monitor both, I can't be the only one. Also, I have the 41402 running at reduced voltage.
MTW MadMax Turbo
EGR Delete
Edge CTS monitoring
post #4 of 10 Old 08-11-2014, 06:28 PM Thread Starter
All these views and no comments. Maybe I am the only one with 2 fuel pressure gauges.
ODAWG714 likes this.
MTW MadMax Turbo
EGR Delete
Edge CTS monitoring
post #5 of 10 Old 08-11-2014, 06:56 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I will say that you are the first guy that I have ever heard of checking your fuel pressure both pre and post cylinder head (especially at the same time). I know that the 41402 on reduced flow setting will flow what an A1000 does at 100% output. So it is not surprising that with 100+ gph of flow you're seeing 8 psi higher fuel pressure before the heads as opposed to after the heads considering that the openings of the 90* fuel fittings are only about 1/4in in diameter. And when you combine that with length of line that the fuel has to go to make it to the regulator, the 8 psi of extra pumping pressure to get the flow (especially at low fuel demand situations like idle) seems reasonable. Hope this helps.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #6 of 10 Old 08-11-2014, 06:57 PM
Heavy_GD's Avatar
Quoted: 1324 Post(s)
Feedback Score: 3 reviews
Nothing here ... Plus the first time I read this I stopped at you asking if fuel pressure affects HP.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #7 of 10 Old 08-11-2014, 07:00 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Fuel pressure definitely affects HP. I had an issue and had to limp home on only 8 psi of fuel pressure and the truck had like no power at all. It really struggled to get up the hills and out of its own way. Now does fuel pressure dropping from mid 50s to low 40s affect power?? I have no idea on that one. I wouldn't think it would help power that is for sure.
Nate
post #8 of 10 Old 08-12-2014, 02:09 AM Thread Starter
I didn't ask if it affected horsepower, I knew it did, but I didn't know that it would have made that big of a difference. I was dropping into the mid 20's. The truck feels like it gained 30-40 HP.
MTW MadMax Turbo
EGR Delete
Edge CTS monitoring
post #9 of 10 Old 08-12-2014, 04:20 AM Thread Starter
Nate, thanks for the response. I was really thinking that it pump volume that was causing the difference in pressures. And as far as the question about the amount of horsepower, no one could ever get me an answer. I just figured possibly 10-15 HP max at the drop it was seeing. It wasn't going into the teens or lower, but I know 10-15 doesn't give the seat of the pants feeling that this did.
MTW MadMax Turbo
EGR Delete
Edge CTS monitoring
post #10 of 10 Old 08-12-2014, 04:23 AM Thread Starter
Nate, Bryan posted on Facebook about maybe you guys doing a dyno event in Akron, Ohio on August 30th. Is that going to still happen? Haven't heard anything about it lately.
MTW MadMax Turbo
EGR Delete
Edge CTS monitoring
