Which Exhaust do I want??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-09-2014, 11:04 PM Thread Starter
jgrin's Avatar
I'm looking at getting the MBRP turbo back 4" system. It's a cat delete system, but it does keep the muffler. I don't mind the whistle the absence of the cat will produce, but I'm hoping the muffler keeps the noise to a level that's not too loud and obnoxious. I'm primarily doing this for less back pressure, more hp, and cooler exhaust temps. Your thoughts would be much appreciated. Thanks!!
jgrin is offline
post #2 of 5 Old 08-10-2014, 12:43 AM
Flo pro makes a turbo back exhaust that you don't have to piece together like MBRP. You can get it with a muffler also.
2005 F250 CCSB 4x4
Yep. It has studs.
seeemmiss is offline
post #3 of 5 Old 08-10-2014, 04:21 PM
You cant go wrong with straight pipe
Dark1244 is offline
post #4 of 5 Old 08-10-2014, 04:43 PM
knuckledragger5's Avatar
Quoted: 9 Post(s)
MBRP turbo back sans the cat sounds great. Fit and finish are great. I did mine for just over $300 including a very nice 5" dual wall tip. Amazon had it for $280ish and XDP has a special edition tip for about $35.
2016 Platinum Tri Coat CCSB F250 Lariat Ultimate, FX4, Factory 20's with the TOYO ATII's
damn trucks loaded, seriously! it has heated rear seats! WTF!
***SOLD***
06 F250 CCLB Lariat FX4
por vida
knuckledragger5 is offline
post #5 of 5 Old 08-10-2014, 07:15 PM
On my 03 the sound of the exhaust is great ecspecially wot going up a hill or something. However the turbo whistle or whatever is pretty darn loud at lower rpms or loads. Different tunes seem to have an effect on it. Matts tunes are the quietest I have but also the strongest.
Mine is MBRP turboback no cat with muffler although the muffler is essentially straight pipe.
2003 F350 Lariat 6.0L
MTW stage 1, 4" MBRP, IPR coolant filter, 05 front cover and water pump, everything else pretty much stock.
Quint is offline
