Deleting/Moving fuel bowl? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By twoicebergs
post #1 of 6 Old 08-09-2014, 10:28 AM Thread Starter
Quoted: 390 Post(s)
I have the BPD remote oil filter system. If I were able to move or remove the secondary fuel filter from it's present location, I could get the oil and fuel filter bowl out of the way and free up some space above the block. I'm wondering if something like a FASS and Reg Return Kit would allow me to remove the whole pedestal, is there other options, etc?
2005 F-350 ext. cab long box, FX4
EDGE Insite CTS w/ fuel pres, EGT, and rear diff temp
Blue Spring
BCP High Idle Mod
DS Bypass Coolant Filter
Rotella ELC
Rotella T6 5w-40 Synthetic
EGR Cooler Delete
Bulletproof Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter
268 000km/167 500 miles as of Jan. 1 2015.
Canadian Mind is offline
post #2 of 6 Old 08-09-2014, 11:20 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
A regulated return would allow a complete elimination of the upper filter housing.
ODAWG714 likes this.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 6 Old 08-09-2014, 11:23 AM Thread Starter
Quoted: 390 Post(s)
Which one? I had a look and the one I seen integrate with the current fuel filter bowl setup.
Further, what would happen with the filter itself?
Blue Spring
BCP High Idle Mod
Rotella ELC
EGR Cooler Delete
post #4 of 6 Old 08-09-2014, 11:38 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Any higher end regulated return would delete the fuel bowl. You route your return from the heads to the regulator then off to the tank. You would be better off getting a new filter pump setup and feed the new pump to the heads and the return from the back to the regulator
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #5 of 6 Old 08-09-2014, 11:45 AM Thread Starter
Quoted: 390 Post(s)
Ok. Thanks for that. Anything you'd recommend off the top of your head?
Blue Spring
BCP High Idle Mod
Rotella ELC
EGR Cooler Delete
post #6 of 6 Old 08-09-2014, 11:47 AM
ODAWG714's Avatar
Quoted: 6 Post(s)
I can pm you a price. Incoming
Oliver
ODAWG714 is offline
