dropping fuel pressure with 175s - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 18 Old 08-07-2014, 07:28 PM Thread Starter
Well guys I have been driving the truck with 175/75s for about 4 months now and have been babying the truck. Well I am tired of only being able to use 1/8th of my pedal. If I mash the go pedal 1/4 of the way it instantly drops to 50 psi on TSD's daily street tune. I have only stabbed it to full throttle once and it bottomed out my gauge. I do not have any fuel upgrades other than the injectors. The question I have is do you all think maybe my factory pump is really weak or is it just because I don't have a regulated return? Either way I have to solve this problem. If the factory pump is the culprit an air dog 150, sump, and RR won't solve the problem will it? I want to do a full fuel system but I just don't plan on keeping the truck but another 8 months or so. So I want it fixed right but dependable and I have heard the A 100 and fuel labs tend to be less reliable. What is everyone's thoughts, and before someone says use the search button I would like to state that I have searched and read all the ones relating that I could find dating back to 2007.
Thanks jonathan
2004 F350 SRW 4x4 CC/SB Lariat black
Current mods:
8" black chrome stack, airaid intake, arp studs, blue spring, and 6.4 banjo bolts, ford gaskets, egr delete, leveling kit, cooper STTs, Warren 175/75, HPOP, TSD tunes, and Coolant filter
Future: regulated return, sump, fass 150
JShe8918 is offline
post #2 of 18 Old 08-07-2014, 07:31 PM
JGman141's Avatar
Sounds like a weak pump, try putting a new factory pump in and see what it does.
JGman141 is offline
post #3 of 18 Old 08-07-2014, 07:34 PM Thread Starter
That is exactly what I was thinking but I wanted yalls opinions before I dropped $600 on a new one.
Current mods:
JShe8918 is offline
post #4 of 18 Old 08-07-2014, 07:43 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 12 Post(s)
I ran the factory pump with a air dog 150 for a while but the factory pump started to die once I went up on injectors. I them did a fuel lab with the air dog. No drops any more
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #5 of 18 Old 08-07-2014, 07:45 PM
ODAWG714's Avatar
Quoted: 12 Post(s)
I would seriously invest in a fuel system. Regulated return and all. It's a big help and when you have decent sized injectors like you do you should be keeping them fueled and happy
Oliver
ODAWG714 is offline
post #6 of 18 Old 08-07-2014, 08:09 PM Thread Starter
I kind of figure that, but I hate to spend $2000 on a fuel system when I am planning to sell the truck in less than a year. I was hoping a RR, sump, and new hfcm may do the trick. Oliver if u will PM me a price on a set up like what your talking about. Couldnt i get away with out a lift pump.
Current mods:
JShe8918 is offline
post #7 of 18 Old 08-07-2014, 08:13 PM
ODAWG714's Avatar
Quoted: 12 Post(s)
Pm sent bud
Oliver
ODAWG714 is offline
post #8 of 18 Old 08-08-2014, 05:59 AM
dieseldan73's Avatar
I have had those same issues for a year. Bought 2 brand new factory HFCM's and even added a Airdog 150 and it never solved my low pressure issues. I should have my new system with larger lines and Fuelab pump done tomorrow.
2005 Ford f350 CCSB King Ranch
MTW MadMax Turbo
Warren 155/30 injectors
EGR Delete
BPD Oil Cooler, FICM, Oil Bypass, Water pump
Flo-Pro 5" Exhaust, Cat Free, Muffler Free
All updated FORD Parts
ARP Studs With Factory Gaskets
PI Stallion Converter
TSD SPD. Thanks Chris,
Edge CTS monitoring
35x12.5x20 Dick Cepek FC-2 on Chrome Rockstars
4" Zone lift with Bilstien 5100's
dieseldan73 is offline
post #9 of 18 Old 08-08-2014, 09:43 AM Thread Starter
Wow. You have low pressure issues with 155/30s? I never would have guessed that size injector would cause problems.
Current mods:
JShe8918 is offline
post #10 of 18 Old 08-08-2014, 10:42 AM
I don't know why. I bought 2 used factory pumps and it didn't fix it. I put a sump and Airdog 150 and it helped but still dropped into the 20's under WOT. I then replaced the lines from the factory pump to the fuel bowl, no difference. The last thing I did this spring was replace the factory pump with not one, but 2 brand new factory pumps and it didn't help one bit. I finally said screw it and I am in the middle of replacing everything from tank to the engine and back. I must have the thirstiest 155/30's on the planet. Everyone on said it had to be the factory pump, but there is no way I had a total of 5 bad ones.
MTW MadMax Turbo
EGR Delete
Edge CTS monitoring
