Airdog 150 and injectors - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-06-2014, 08:52 AM Thread Starter
Mexfdmnb's Avatar
Hey guys just a quick question. Up to what size injectors will an airdog 150 support? I am currently running stock inj. And stock charger. Just wanted to know for later down the line when I decide to upgrade. Also please post your the set up you are currently running with an Airdog 150. Thanks.
[SIGPIC]2005 F-250 CCLB zf6
leveling springs, 4" turbo back 5" tip
oil filter bypass, coolant filter
deleted, studded, sinister fuel filter cap,
SCT X3, S&B CAI, blue spring,
truxedo lowpro qt bed cover,
black diamond hg,
stand pipe, dummy plugs, stc fitting, Airdog 150,
Beans Diesel sump, edge insight cts, eadge eas pyro, turbo feed line,
Turbo drain tube, mishimoto 200* t stat, WW2
CCV MOD, High idle mod, PMF traction bars, 08 diff cover, 20" led light bar
Mexfdmnb is offline
post #2 of 4 Old 08-06-2014, 10:10 AM
JGman141's Avatar
Airdog 150 just feeds your factory unit, basically takes stress off of it. I've seen people run 190/30s and have decent fuel pressure, as long as the stock pump is healthy.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #3 of 4 Old 08-06-2014, 10:25 AM Thread Starter
Mexfdmnb's Avatar
When I do upgrade 175/75 are the biggest I plan on running.
black diamond hg,
Mexfdmnb is offline
post #4 of 4 Old 08-06-2014, 10:39 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I ran 175:75s with it and it worked fine. But once I jumped up it fell flat on it's face
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
