Are Dowels needed when studding? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By RiverSide
  • 2 Post By Six0~Stroker
  • 1 Post By toren302
post #1 of 10 Old 08-04-2014, 03:17 PM Thread Starter
I have a 18mm block and a 20 mm head (I know I have to swap stuff and I am ok with that). My question is do you really need the dowels when the studs keep the gasket in place? Has anyone tried this?
Great River is offline
post #2 of 10 Old 08-04-2014, 03:19 PM
Dts327's Avatar
my oem gasket set came with a set of dowels that were 18 on one side and 20 on the other, I was confused to this at first but now I see why they did it
2007 ccsb, Arp studs, stock HG, kc billet wheel powermax turbo, Banks intercooler kit, egr delete, stock downpipe followed by 4in straight, updated oil pipes & dummy plugs, stc fittings, SCT idp custom tunes, edge cts monitor, blue spring update, new oil cooler, elc coolant, airraid cold air intake, 35x12.5x18 Toyo mt's, rancho rs9000 shocks
Dts327 is offline
post #3 of 10 Old 08-04-2014, 03:29 PM Thread Starter
Funny to me how the step downs are $25+ each but in the Kit. A bit greedy of Ford. Ford must really hate 6.0 owners.
post #4 of 10 Old 08-04-2014, 03:53 PM
Dts327's Avatar
damn if I didn't throw them away last week I would have put them in the mail for you, sorry man
Dts327 is offline
post #5 of 10 Old 08-04-2014, 04:03 PM
portcity_gt's Avatar
Quoted: 1193 Post(s)
The studs do NOT keep the gasket located, theres too much wiggle room. Yes you need the dowels. Are you not using oem gaskets?
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #6 of 10 Old 08-05-2014, 01:09 PM
RiverSide's Avatar
Quoted: 4 Post(s)
just did my HG and have 2 set of 18/20 mm dowels, you can have them.
i hope you are not in a hurry cause i have to ship them from Amsterdam-NL
bgraiders323 likes this.
'05 F250 Harley Davidson Crew Cab'4x4 Powestroke diesel 6.0
ARP - Egr delete - Hpop upgrade - Blue Spring upgrade - Catepillar ELC EC1 coolant - Coolant Filter - edge Insight monitor- SCT Custom tunes - EGT & fuel pressure - Zone off road radius 4 inch lift - Dual steering stabilizers -Krank fuel 9x20 -rims - Clarion NX702E
RiverSide is offline
post #7 of 10 Old 08-05-2014, 05:11 PM Thread Starter
Thanks for your offer...but I think I want to get my truck up this weekend....maybe the next time I am in town I will stop by.
I am have a set of the black diamond gaskets.
I almost bought another set...until the dealer here in Mandan North Dakota quoted me $100 over list.
Has anyone ever tried this. I can not get the gasket to budge.
I believe these are more for assembly line vs a stud job!
post #8 of 10 Old 08-05-2014, 05:27 PM
Quoted: 341 Post(s)
Feedback Score: 5 reviews
Good luck redoing the job if you don't use the centering dowels. The bolts DO NOT center the gasket into the proper location.
toren302 and ODAWG714 like this.
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #9 of 10 Old 08-05-2014, 06:14 PM
Not mention the heads.....this is an area where thousandths of an inch matter.
post #10 of 10 Old 08-06-2014, 10:44 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1610 Post(s)
What all of these guys SAID!!!!
There was a guy on here not to long ago that did this and all the valves touched on the passenger side head. I was the only one in that thread saying it was a bad Idea. He came back on and put all the blame on the machine shop for decking the heads too much even after I pointed out that he used 18mm dowels on 20mm heads. USE THE RIGHT DOWELS....or if you don't, then you deserve what you get in the end. They aren't there to help you hold the head in place. They are there to locate EVERYTHING PROPERLY!!!
ODAWG714 likes this.
toren302 is offline
