Need some help on my 03 looking to get dependable performance - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 13 Old 08-04-2014, 02:43 PM Thread Starter
2003 f250 6.0
I know there are people out there upgrading their 6.0. So I just wanted to get some input, so i can do the same to mine. Recently the icp sensor went out, so I replaced it but I still have a little leak from there. Because I was not able to torque it down to the right spec. But Iím not worried about that now i just wonít drive her till i get what i want done. I plan on pulling the motor and cleaning it up and making sure everything still in spec. Before i start upgrading now what i want is at least 500 hp but i want it to be dependable. Right now i am in school and veteran so i am on a budget. I would like to get all the parts for the truck before i put her down for a while. So i would like input on where can i get the parts for cheap but quality i have a list of things i am thinking to do right now. Oh and does anyone live in Texas near the Dallas area i live in Allen TX
Metal ipr screen
Turbo oil drain
Oil System Stand Pipe
Dummy plugs read that i donít have them my year
Blue Spring" Upgrade Kit 3C3Z-9T517-AG $64.31
6.0L VGT Turbo Rebuild Kit 03-07 134.81
Sinister Basic 6.0L Solution Package with Sinister EGR Delete Kit, Oil Cooler and Coolant Filter Kit $794.00
SCT iTSX 469.00
Flex-a-lite 272 Diesel Truck Cooling Fan $669.95
Arp studs and stock head gaskets
AFe Blade Runner 3" Intercooler Tube Out; Ford Diesel Trucks 03-07 - 6.0L $179.00
Pillar 3 gauges
cyphermike is offline
post #2 of 13 Old 08-04-2014, 07:52 PM
MWilbur516's Avatar
Originally Posted by cyphermike View Post
2003 f250 6.0
Metal ipr screen
Turbo oil drain
SCT iTSX 469.00
Pillar 3 gauges
These mods should put you in the 430-450RWHP range with a good custom tune.
Sent from AutoGuide.com App
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #3 of 13 Old 08-05-2014, 03:07 AM
Powerhead357mag's Avatar
I wouldn't waste your money on the electric fans. They don't flow near as much as the factory can so towing and stop and go traffic could be an issue.
03 CCSB F-250KR daily.
Sct Super panty dropper and Loony
4in axle dump
Blue Spring
03 SCLFB DRW F-350 pull truck
Completely stock!!!
Powerhead357mag is offline
post #4 of 13 Old 08-05-2014, 05:14 AM
MWilbur516's Avatar
I know several guys with electric fans that tow, pull competitively and race and have never had an issue.
I have confidence that he would be fine with electric fans and not have the associated issues that some guys have when installing an EGR delete and removing the EGR valve.
post #5 of 13 Old 08-05-2014, 07:05 AM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I have a beautiful ported intake that will satisfy your needs
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #6 of 13 Old 08-05-2014, 10:48 AM
peixinho's Avatar
Quoted: 174 Post(s)
If you have a serious goal of 500hp then you are going to have to ditch the stock injectors and turbo (95% of the time).
500hp is pretty easy to reach with a small turbo and injector upgrade. You should not need a tranny of fuel system upgrade and the truck should still spool very fast.
175/stock injectors and a stage 2 turbo (475-515hp)
or
175/stock injectors and a stage 1.5 turbo (450-500hp)
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #7 of 13 Old 08-05-2014, 12:35 PM
mrenn's Avatar
Quoted: 3 Post(s)
I'd ditch that stock intercooler while your at it before you blow the plastic ends out. Just a thought.
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #8 of 13 Old 08-05-2014, 01:02 PM
I'm in the Mansfield area. Doing injectors and a tuner will get you to the 500 hp you are looking for. According to the numbers on my SCT X4 I should be getting a little over 400 hp and 700 lbs torque. PM if you wanna chat.
2006 F250 6.0 ltr
Egr cooler/Egr delete
3.5" stock down pipe with a no name 4" straight pipe, resonator and muffler deleted. Because let's face it, exhaust pipe is exhaust pipe no matter whose name is on it
SCT X4 Tuner -
Looney Tune by QuickTricks
Fuel Pressure Regulator Blue Spring Upgrade
PPE Oil Cooler
BD-Power Coolant Filtration
Zerex EC-1 Coolant
Delo 400LE 15w40
JohnnyJackMac is offline
post #9 of 13 Old 08-05-2014, 08:59 PM Thread Starter
sorry its taken me so long to get back to you guys yea i was thinking about getting an inter cooler upgrade to but i am working on a budget that kills a lot of things i want to do any other thoughts about all the upgrades i have listed so far and yea part of my fan shroud is busted from belt braking at 80 mph from previous owner and i figure if i can take drag off engine then i can get hp also a lot of car now and days run electric fans maybe i will do more research on that one also just wanted to run this by you guys my buddy says that i can get my stock injectors rebuilt to put out more what thoughts on that because the cost of buying new ones could take up all the project money
post #10 of 13 Old 08-06-2014, 09:30 AM
MWilbur516's Avatar
You can have your stock injectors modded to 175/stocks for relatively cheap. I'd call Rykan at Holders Diesel.
Also , a ported intake from WPE should be on your short list.
I'd recommend Vision a Diesel (me), KC (Charlie) or Barder (James) for a turbo upgrade. Any of us can set you up with a great turbo.
As for the intercooler, I think you'll be fine. You are going to Max out around 35psi of boost and that well within the limits of the stocker. If you want to upgrade, look at the BulletProof a Diesel kit. It'd be.a great budget friendly answer for you.
Pro fuzz, Merc82 and snafu! like this.
