Difference between SCT 7015 X4 for $400 vs $750? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-04-2014, 11:59 AM Thread Starter
RamAirfreak98ss's Avatar
Quoted: 4 Post(s)
Garage
What is the difference between the 7015 and a 7015-C? Are they the same unit or one is really a competition model?
One is $400~ and the other is $725-800? I guess the more expensive one can handle the deletes?
04 F350 XL
06 F350 Lariat SRW BPD oil cooler, ARP, sinister !egr, s&b intake
06 F350 Lariat C/C DRW 4" Silverline , BPD egr cooler, ARP studs, Garett powermax turbo
07 F550 XL c/c 12' ABC american landscaper
11 F350 Lariat C/C !dpf/doc, SCT 7015
14 F550 Lariat C/C Dump truck, !def/dpf, Flo-Pro, T1 Tuner, S&B intake 3200miles
16 F350 Lariat c/c Nov 2015
RamAirfreak98ss is offline
post #2 of 11 Old 12-15-2015, 05:55 PM
DayTrader's Avatar
Quoted: 138 Post(s)
I have the same question...ashamed no one answered
Through Christ all things are possible.
DayTrader is offline
post #3 of 11 Old 12-15-2015, 06:04 PM
Weberman3's Avatar
Quoted: 398 Post(s)
Send a message via MSN to Weberman3
I believe the more expensive one is for the 6.4 and 6.7 with the DPF delete.
2004 F350 XLT 6.0L ZF6 CCSB FX4
ARP Head Studs, EGR delete, Factory straight piped, Fuel Sump, Sinister Coolant Filter, Rotella ELC, AutoMeter Gauges, NUC Oil Bypass
Kenwood DDX372BT Touchscreen, Kenwood Rear View Camera Rockford Fosgate P1683s powered by P400.4
Weberman3 is offline
post #4 of 11 Old 12-15-2015, 06:13 PM
DayTrader's Avatar
Quoted: 138 Post(s)
So the regular 7015 will not work with the DPF delete?
post #5 of 11 Old 12-15-2015, 06:24 PM
Weberman3's Avatar
Quoted: 398 Post(s)
I'm not sure exactly. I would assume so since the 7015-C is under the 6.4 and 6.7 sections on sites.
The Following User Says Thank You to Weberman3 For This Useful Post:
DayTrader (12-15-2015)
post #6 of 11 Old 12-15-2015, 07:01 PM
Quoted: 762 Post(s)
It's the "off-road" model.
Corey@CNCFAB is offline
post #7 of 11 Old 12-15-2015, 08:05 PM
Powerstroke 4 Life's Avatar
Quoted: 3 Post(s)
So the $400 one is stock off the shelf generic stuff, the $700-800 one should have the "good stuff" on it.
2010 F250
LARIAT FX4
STOCK...
Powerstroke 4 Life is offline
post #8 of 11 Old 12-15-2015, 09:06 PM
Master_Chase's Avatar
Quoted: 376 Post(s)
From my understanding that for the 6.0 you can get either to turn off the EGR, but if you want to turn off the DPF (because it's missing) on a newer diesel then you need the more expensive off road tuner.
Early 2003 6.0 Excursion fully bulletproofed, 155/30 injectors, KC Stage 2, and a lot of other stuff. Thanks to everyone on the forum I have learned a lot.
The EGR does to your engine what smoking does to your lungs.
Remember you can always improve on a design until the EPA gets involved.
Master_Chase is offline
post #9 of 11 Old 12-16-2015, 03:57 AM
Quoted: 762 Post(s)
You're better off getting the $399 SCT then buy custom tunes for the 6.0 trucks. The 7015-C is more for the 6.4 and 6.7 owners.
post #10 of 11 Old 12-16-2015, 03:36 PM
DayTrader's Avatar
Quoted: 138 Post(s)
Yes. Making sense now.
