I'm replacing my FICM.. which aftermarket supplier is #1 - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 22 Old 08-01-2014, 12:05 PM Thread Starter
nitecop559's Avatar
Quoted: 2 Post(s)
Hey guys.. I own a 2006 F250..my FICM crapped the bed. I checked on a factory module and they want $700 plus for more factory junk that I'm sure will fail again. Question is who's the best Aftermarket supplier of 58v FICM's? All opinions are welcome. I'm trying to make a well informed purchase here. Needless to say I've sunk enough green into this motor.. Trying to get the best bang for the buck.
If you find yourself in a fair fight....your tactics suck!
nitecop559 is offline
post #2 of 22 Old 08-01-2014, 12:25 PM
Did you check on the price of a half shell ficm.. You can change just the power supply portion of your FICM with a new one. I think those are about $300.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #3 of 22 Old 08-01-2014, 12:29 PM Thread Starter
nitecop559's Avatar
Quoted: 2 Post(s)
I'm open to that. When I spoke to the factory parts guy I got "geeze I don't know if you can get just the board" and "58v?..i don't know what the voltage is.. It doesn't say" my issue isn't what to get.. It's from whom..
post #4 of 22 Old 08-01-2014, 12:37 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
58v ficms are from bullet proof diesel, around 500ish bucks.
kinnisoj likes this.
MrOneEyedBoh is offline
post #5 of 22 Old 08-01-2014, 12:46 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
^^^^Yup, you cant beat Bullet Proof's set up.
Now that I have said that I would also like to say that their is other routes that you can go. FICMRepair.com is awesome. And I bet you will have a tought time trying to find someone on here that is not happy with Ed's work. That is who took care of mine. And so far the truck couldnt be happier.
You can also go onto Amazon and get the Dorman Ficm. This is what my brother did he is happy with it.
But I will say again the bullet proof diesel is the best that you can get. They are spendy for sure. But you wont hear anybody regreting getting one. And when/if mine craps the bed if I got the extra fun money laying around Ill probably go this route.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 22 Old 08-01-2014, 02:44 PM
portcity_gt's Avatar
Quoted: 1361 Post(s)
Bulletproof diesel
/thread
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #7 of 22 Old 08-01-2014, 02:54 PM
Term3's Avatar
BPD FICM power supply, every single part of it is brand new, not upgraded parts on the OEM board. You can set it at 58, 53 or stock 48 volts. The 53 setting will keep it just under the "Over voltage" code which gets dealership mechanics excited when they see it because they are convinced there's a short in the FICM no matter how many times you tell them its suppose to be that voltage.
Sent from AutoGuide.com App
jmeaby likes this.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #8 of 22 Old 08-01-2014, 08:27 PM
Hillz's Avatar
Quoted: 2 Post(s)
Give Ed a call. even If its only for information. He is a fountain of FICM information. Great guy to talk to!
2005 F250 4x4 ECSB.
Stage 2, SCT X3, ARP , 4" turbo back Magnaflow duals, No limit CAC, S&B CAI, EGR delete, Dieselsite coolant filter, Nuc engine oil bypass filter, Dfuser fuel cross over, GoGo direct solenoid, Autometer gauges, 2.5" leveling, 35`s, Bilstein 5100, Rear air bag, 7.5` Arctic poly plow
Hillz is offline
post #9 of 22 Old 08-01-2014, 08:39 PM
jmeaby's Avatar
Quoted: 16 Post(s)
lets talk about ficm's
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #10 of 22 Old 08-01-2014, 08:40 PM
jmeaby's Avatar
Quoted: 16 Post(s)
bulletproof diesel again is the best, but how are your batteries and alternator? a lot of times (not always) the ficm goes out because its not getting enough voltage during start up. there is lots of stuff in that thread and i hope it helps
04 f250 cc sb.
jmeaby is offline
